Old 12-14-2013, 09:27 PM
Jonsey Jonsey is offline
Very clean solution.
Old 01-22-2014, 08:31 PM
LPI's Avatar
LPI LPI is offline
Default Serp drive W/EFI and CTB
Here is a system we are working on for a customer that will incorporate the Holley 60-2 crank trigger ring and their sensor with our mounting brackets.
The CTB assembly will work with our new 6 rib serpentine drive belt system with a spring loaded tensioner for the alternator, gen II power steering pump w/remote reservoir and the Sanden 508 style compressor.
The trigger wheel will be mounted to the balancer behind the crankshaft pulley.
We will post pictures as the parts get completed.
Holy cow Tom that's a dirt road...
www.luhnperformance.com
Old 01-22-2014, 08:44 PM
Ollie's Avatar
Ollie Ollie is offline
Something like this.
Its ok to giggle and snicker, Dont laugh and point
Old 02-02-2014, 07:35 PM
darbikrash darbikrash is offline
Making a little more progress with the 461. EFI is a Holley HP system. While not the cheapest solution, I like the Injector Dynamics LS style injectors. These are the shorty ID725 high impedance injectors mounted on a Torker II EFI intake, ported to match the heads by Dave at SD Performance.
Fuel rails are Edelbrocks.
I fabbed up some stainless standoffs to raise the fuel rail slightly higher to accept the 48 MM (O-ring to O-ring) injector height. No changes needed to the intake.
I also added a 1.5" Wilson spacer under the throttle body, this buys me some additional plenum volume, and raises the throttle body high enough to let the linkage clear the fuel rails.
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
The Following User Says Thank You to darbikrash For This Useful Post:
