#121
Old 12-17-2013, 03:08 AM
Formulabruce's Avatar
This thread should be renamed... "Stock appearing"
" Long may we DRIVE !"
  #122
Old 12-17-2013, 08:35 AM
Guess Bruce is another non believer
That's okay, run into many guys like this over the years. It's a common response from people that don't fully understand what's going on here, or from people that just haven't tried it themselves. If you can't beat em', you may as well join the fun Gotta respect guys that aren't afraid to do what these cars were born to do, and get out here and ring these expensive cars (not to mention expensive parts and pieces)
Since we are on the subject, here is Mahoney's ram air II bird that's one of the quicker pontiacs I'm aware of.
http://www.youtube.com/watch?v=yJjya...yer_detailpage
  #123
Old 12-17-2013, 08:51 AM
Judge273's Avatar
Judge273 Judge273 is offline
The PSMCDR is a event that is only in Michigan as I understand. The intent is not to distort or use tricks, but to have a platform of unity and drag race for "no awards".
Mike/Illinois
  #124
Old 12-17-2013, 09:02 AM
Correct, however there is another entity running called the F.A.S.T. series that has branched off from this several years ago, and they run a class called "Factory Stock" which is basically the same thing as the Pure Stock racing running assentially the same rules and tech.
However F.A.S.T. has several races throughout the year at different venues, so it's easier to plan and attend, and it's always fun to see the so called "ringer" cars as some of you guys are calling it, those would be the F.A.S.T. cars or "Factory Appearing Stock Tire" cars that Bruce is referring to.
For more info on this group check here... http://www.fastraces.org Their event schedule is likely to have something nearby most of you anywhere in the midwest.
Matter of fact you'll see another one of Mahoney's ram air birds on the front page, this one obviously setup to run the F.A.S.T. series.
  #125
Old 12-17-2013, 11:40 AM
transam1972 transam1972 is offline
Default 455 H.O.
I did not factor in how rare the RA IV is..a lot more 455 H.O.s,mine being one of them...as I stare at the engine,tell me what I should do..58k on the car,bought from the original female owner in 85...engine swap so good,I never knew it has a complete SR motor,heads and carb. from 73...that alone may drop the motor miles to 48k..car has always been garage kept...before I go racing do you advise pulling a head and valley cover to really inspect this engine?...I hope to hook up with my brother who does this...I just painted my engine OER blue,thats my engine work...it seems the 455 H.O. was just an all around highpoint of the roundports...but no one can argue that to own a Ram Air IV or a 455 S.D. is not a good thing...to see these engines still being raced is very cool
  #126
Old 12-17-2013, 12:11 PM
Are you saying you want to hit the pure stock or factory stock drags at some point? Probably alot of prep that could be done but I would personally recommend keeping it simple and getting your feet wet so to speak. Get a feel for it and meet some people, most are all friendly and willing to share help and tips. I guarantee once you have a taste of it you'll be hooked and looking for more.
Myself I just enjoy the sounds and smells of these old cars racing, and it's all heads up racing like it used to be, none of that silly index and handicap stuff. You don't have to be the fastest guy, after qualifying they'll pair you with a similar running car and go heads up 2 out of 3. So some of the matches can appear strange at first, but real eye openers when the light turns green. Lots of fun and sure beats sitting around in a lawn chair dusting the car off, that's something I got tired of doing a long time ago. Speaking of which any one of these cars would win and/or stand proud at any local show, some really nice stuff comes out for racing.
  #127
Old 12-17-2013, 12:27 PM
tjtjwdad tjtjwdad is offline
Originally Posted by 71HOT/A View Post
What if you built what Pontiac probably would have if not for the new regulations. Take one 455 HO, raise the compression to about 10 to 1, add the IV cam and 1.65 rockers. Some SD rods to make it stay together and team this up with an m22 and 3.73 rear. Guess what, you would have a car that will run on today's gas, is more driver friendly than the IV and considerably faster.
I would consider strenghting the bottom end; connecting rods, crankshaft, pistons, cross bolt man bearing caps to take advantage of upper RPM range of the 041 camshaft and 1.65 rocker arms.
Since you're adding the 1.65 rocker and the RAIV camshaft I would strongly consider the valve train components as well; springs, push-rods, push-rod guides and lifters. Also, IIRC the RAIV had larger rocker arm studs but I'm not sure on that one. Just as well to get the whole package while you're doing the project.
  #128
Old 12-17-2013, 12:50 PM
Default gone racing
in 1981 I was in a Trans Am/Formula Firebird club..I got to run my 76 455 3xs in the 1/4 mile at Englishtown..one of the highs in my life that same year was doing a parade lap at Dover Downs..incredibly banked...after the lap you were allowed to go full throttle..I know I was pushing 100 mph..my friends 71 bue T/A lost a trim ring and it looked surreal as it moved across the track and did not hit any cars...I wonder if this is still allowed..in fact I still have my day at the races photos
  #129
Old 12-17-2013, 01:05 PM
4birds's Avatar
4birds 4birds is offline
Default RAIV vs 455HO
Wow. This has gotten way off the original topic of a Ram Air IV engine versus a 71-72 455HO. Many of us (OK some of us lucky bastards) have driven both of these cars with these engines in close to original GM "born with equipment". This means no headers, bigger cams, rear gears, slicks, super tuning, etc. Anyone can modifiy and tweak things to perform better. Thats not the question here.The point is both of these engines were top performers and were VERY CLOSE competitors to each other as GM designed and build them back in their time. Today NONE of them are stock as they were back then. That said, I am glad there are so many of them still in existance today to still have fun and enjoy these fantastic machines! They bring people together for spirited chats!
The Following 3 Users Say Thank You to 4birds For This Useful Post:
  #130
Old 12-17-2013, 01:23 PM
2manyT/A'S's Avatar
Hmmmmm,didn't there used to be a "poll" feature on the forums....that's what we need...
Eye Candy......garage band?
Go full screen & turn it UP!
  #131
Old 12-17-2013, 01:33 PM
Originally Posted by 4birds View Post
Wow. This has gotten way off the original topic of a Ram Air IV engine versus a 71-72 455HO. Many of us (OK some of us lucky bastards) have driven both of these cars with these engines in close to original GM "born with equipment". This means no headers, bigger cams, rear gears, slicks, super tuning, etc. Anyone can modifiy and tweak things to perform better. Thats not the question here.The point is both of these engines were top performers and were VERY CLOSE competitors to each other as GM designed and build them back in their time. Today NONE of them are stock as they were back then. That said, I am glad there are so many of them still in existence today to still have fun and enjoy these fantastic machines! They bring people together for spirited chats!
Well said, I will add... Trans Am was NOT built from the factory as a DRAG race car... but thats where the conversation always goes..
Original dyno reports tell the story on HP and torque at what RPM...
  #132
Old 12-17-2013, 01:47 PM
Originally Posted by transam1972 View Post
does anyone on the forum own a 1970 T/A Ram Air IV?...and it being high compression were they "harrier" than the 1971 and 1972 455 H.O.s?
THIS above is the OP...
A smaller cube engine with a big cam will ALWAYS be "harrier" than a big cam in a 455...
Yes I drove em both, with Sunoco 260 .. ROAD race cars, NOt dragsters......
  #133
Old 12-17-2013, 02:39 PM
Default RA IV vs. 455H.0.
does not the 455 H.O. have,out of the crate more potential and a better running engine than the RA IV?
  #134
Old 12-17-2013, 02:55 PM
No, to answer the "more potential", not with stock internals & stock flowing heads.
  #135
Old 12-17-2013, 03:05 PM
Default T/A vs. T/A
so stock to stock, a RA IV will beat a 455 H.O.
  #136
Old 12-17-2013, 03:24 PM
4birds's Avatar
Wink TA vs TA
Maybe, maybe not. Depends on what color it is.......
The Following User Says Thank You to 4birds For This Useful Post:
  #137
Old 12-17-2013, 03:43 PM
brians's Avatar
brians brians is offline
Personally got to go with the RAIV as purchased, but believe the 455HO has more potential as a street engine.
Most of my TA’s are gone now, but here is what the early ones ran:
1972 – All original but was an auto with a 3.08 gear. Best was a 14.52 @95
1973 – Original with 30K miles - base 455 4sp with 3.42. Best was a 14.40 @ 97
Changed the M21 to a M20, put in a 744 cam. True duels with manifolds.
Best 13.89 @ 102
(Switched to 400 4X heads and put the 72 HO intake and carb on it. Best 13.20 @ 105)
1970 RAIV – Auto with 3.73. Never drove it all the years I had it (really stupid mistake)
Was in it before I bought it - Best was a 13.98 @ 102 and an ugly 60ft
“If you ain't first, you're last” - REESE BOBBY
The Following User Says Thank You to brians For This Useful Post:
  #138
Old 12-17-2013, 03:55 PM
LOL!
Glen, what many of us are saying is the RAIV has a higher potential in race engine form.
Bone stock for bone stock with the lousy stock '70-72 F-body rear exhaust system, both the '70 RAIV T/A & similar equipped '71 HO T/A were near dead heat.
  #139
Old 12-17-2013, 04:17 PM
Default Trans Am 1970 to 73 my favorite
I know, tell me though Ol Pinion,..should I pull a head and check the piston for wear on my engine?...I do want to do everything right for this motor
  #140
Old 12-17-2013, 04:38 PM
Beat it doing what??
1/4 mile, maybe..
TEXAS mile, NO WAY..
can this ever end??
