#321
Stan
| The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
#322
Half right. Foolish
EHTTFMF! Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead. BEING STUPID WORKS THE SAME WAY! The rest of us suffer. |
#323
So, an ehead HP is less than a Visner head HP?
(what's that head called anyway?)
#324
I do not know what to say besides wow. That is all.
#325
Mike,
What NHRA Pro Stock has done is shift the torque curve to a higher RPM. With all of your knowledge I am sure you understand what that does. Stan Ps- Keep the BS coming it has been a bad day and I need the comic relief.
#326
3 out of 5?
![]() Quote:
| The Following User Says Thank You to Aaron Quinton For This Useful Post: | ||
#327
That one makes me laugh when people post that one! |
#328
I dunno what's a going on. all i know is,
the beer is good right now, any race fella needs to get the engine into the peak HP region to do the most work the most quickly. BUTT, how do you get there & and stay there with gear-fixed RPM sweeps, until the next shift? 6-speed transmissions? Say it isn't so! |
#329
Suppose 1 engine has 600 HP at 8000 rpm, vs an engine with 570 HP at 6000 RPM.
when a fella plots the HP & TQ of each engine, the 570 HP @ 6000 RPM may jump out as a real gem. I'll pick that 570 HP @ 6000. HIS
#330
Lil Jack,
I will see your - CV1TTFMF and raise you a VBHTTFMF ![]() Stan
#331
we shall see.
#332
How do you not get that an engine that makes peak hp at 6500 will make less average. Period.
#333
My 2 cents, not trying to argue or pick sides but my observations working in and around race cars for a couple years: area under the curve is more important that peak, the engine spends more time under the peak than at the peak. Also, nitrous is a power ADDER, a 100 shot is 100 everywhere throughout the HP curve. 500HP @ 8000 RPM will out run 500HP @ 10000 RPM anytime especially with a torque converter equipped car.
Right now I'm building a car to run in heads up class, NA 7#/CID, car is now 499.999 CID and 3500#, will a smaller engine at less weight be faster? Rule of thumb: it's OK to beat your wife with a stick as long as it's no wider than your thumb, its true look it up
1989 Automotive Hall of Fame Inductee |
#334
Mike,
I have the utmost respect for you and the numbers your car runs. I hope my car can achieve what you've done in the future. In theory, hp is what moves a vehicle. It doesn't matter if it's an 800 hp Pontiac at 6000 rpm or an 800 sbc at 9000 rpm moving the car. If the cars are able to deal with the power applied, they should run the same numbers. The difference may be in the instantaneous torque levels applied by the crankshaft to the rear end. The torque measured during a dyno pull is the average torque vs. rpm. The running engine produces a sine wave torque pulse that has highs and lows vs. the average. The higher rpm engine will have more pulses that have lower highs and lows as compared to the lower rpm engine. Maybe this is enough difference to allow the higher rpm engine to have traction to accelerate the car vs. the lower rpm engine due to the lower torque pulses applied to the tires. What do you guys think? This never occurred to me until I had a discussion with a seasoned motorcycle road racer years ago. I'm a big 2 stroke GP fan that has been disappointed ever since 4 stroke engines took over GP. I had a discussion with this guy and never understood why the 4 stroke engines took over. He had ridden both 2 stroke and 4 stroke engines with similar power and was faster on the 4 stroke bike. His feedback was the 4 stroke bike had higher torque pulses which let the rider know better when the bike was closer loosing traction as compared to the 2 stroke. The 4 stroke bike provided more rider feedback on traction limitations than the 2 stroke providing more confidence for the rider and faster track times. This was a revelation to me as a novice 4 stroke rider. Maybe the lower torque pulse engine (higher rpm) allows a traction limited car to run faster (the opposite of the motorcycle example in a real world applciation)? Stan, can you modify your code to take into account the torque pulses if it doesn't have this capability? Maybe Mike and Stan are both right and we just have to bridge a minor gap in experience vs. practical application. Let's pull together and move forward instead of pissing at each other! Merry Christmas to the PY crew, Aaron Quote:
#335
![]() They reason most rev higher (like Pro Stock) is that they can't make enough HP at the lower RPM. Per the equation more RPM equals more HP even if the torque stays the same. They have exhausted about all there is to get out of the engine at a certain RPM. So, if they work on getting it to rev higher it will make more HP. Doubt the 'average' HP or area under the 'curve is any better? ![]() But this is basic math, so maybe some can't handle it?
#336
You seem to think those little HP guys can tell what is producing them.
#337
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
| The Following User Says Thank You to twooldgoats For This Useful Post: | ||
#338
this again makes my point. hp is hp was the comment. "with a power adder the 100 extra is everywhere" the peak number is not the holy grail. the average will affect the acceleration more. rpm in the range i gave will be faster 9 outta 10 times if not more NA. 800 peak@ 6500 will get whooped by 800 that peaks at 9000. The whole usable curve is way above 5250 and the average power will be higher. The engine that peaks at 6500 has part of its power curve at or very near 5250 so its average will suffer. Its math guys, not emotion.
| The Following User Says Thank You to mike leech For This Useful Post: | ||
#339
#340
i will simplify this.
FOOT ON GAS PEDDLE = GO FAST.. EHTTFMF VISNERS TTBMF!
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046s 1.079 4.52 155.15 3000 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! 7.17 @ 188 1/4 mile (2024) Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
| The Following User Says Thank You to Jeff Kinsler For This Useful Post: | ||
