I think that these heads would rock and roll in a blower combination. They would also help a turbo combo, as well...but not as much as a blown combo.
We've had a grand total of zero head gasket issues since we went to the added head bolts on the E head. The billets might not even need the extra studs, especially if you had room around the stud to go to a 9/16" stud like Eric and Mike did with their Fives. That would sure be an added bonus...less crap to deal with is always a good thing. |
10 head studs is plenty if you have a stiff enough head to bridge between them....and spread the combustion loads to more than just the 4 closest studs. Boss Bird has zero head gasket leakage and we're still on our first set of copper Flatout gaskets..
Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” Last edited by Elarson; 12-23-2013 at 12:29 AM. |
The Visner billet heads look pretty stiff and I think they'll probably seal great.
Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
Why not on both?
Would definitely pick both combinations up, no doubt.
Blown engines rely a great deal on the ability of the cylinder head and camshaft to move air through the engine; the compressor is tied to the front of the crankshaft. With a turbocharged combination, the air compressor is not tied to engine speed, so there is a little bit more latitude with what we can get away with. You will see a lot of folks that say "bolt a bigger head on, and you'll make more power with less boost". Most times, that is a fact with a blown combination. And most (not all, but most) times, that statement is total fiction with a turbocharged engine. They are two totally different animals that are typically run in different ways on the racetrack. |
cptinjak, thanks for the info on your head.
How long did it take to make Jack's head? He said 3 1/2 months, but that seems long for a CNC'd head. Also, the head still needs port work when you're done maching it? It looks like a great head and will make some serious power.
As I said before it would have been done in three months but there was an issue with one of Davids machines. David said he could finish the ports, but Gaby wanted to finish them his way specifically for a PA car. |
| The Following 3 Users Say Thank You to Scott Roberts For This Useful Post: | ||
Let say...these heads set the pontiac world on fire....would visner ever consider casting these heads for the common folk?
Thanks, Tom Syron |
Jack
Visner Engine Development, LLC. |
