#41
Harry,
Thanks for posting your results as this is indeed an apples to apples test if there ever was one. It doesn't get any simpler than that. Keep posting results if and when you have the time because it is appreciated. Paul
Sandoval Performance www.sandovalperformance.com Pontiac Crate Engines CNC Edelbrock heads Custom Ground Cams JOHNSON Limited Travel Hydraulic Roller Lifters |
| The Following User Says Thank You to paul s. For This Useful Post: | ||
#42
![]() Thanks for taking the time to post.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
#43
That crossover on the 67 intake has seen some serious temperatures. Is the exhaust flapper stuck in the closed position??
![]() Aluminum intake doesn't have a crossover. Apples to... coconuts. |
#44
good observations; Was this all said with your Avatar ?
#45
We all appreciate you sharing your testing as always we welcome sharing of actual dyno testing and drag strip testing but I don't believe this is an apple to apple comparison at all. The square bore carb on a Q-Jet manifold is a big mis-match. How about repeating the test using a Cliff prepped Q-Jet on the factory manifold and then put the Q-Jet on the square bore manifold with an adapter and see how that works. That would be another apple to coconut test but never the less it would be interesting to see those results.
Tim Corcoran |
#46
Tim, I started my own thread on the topic....and...if you need any testing of the sort mentioned, I've done a LOT of them, dyno, and at the track, with every intake manifold and type of carb I could fit under the hood. We have a lot of test results with Victor/Dominators, and comparisons to T-II/HP 950's, and the Tomahawk intake with Q-jets and large CFM Holley type carburetors, in addition to scores of comparisons between q-jets, Holley's, Demons, etc on all sorts of intakes, with all types of spacers as well.
This happens since I do build a LOT more engines than I mention on the Boards, and we dyno just about every single one of them. Since much of the testing gives us results that don't sit well with certain "crowds", I put very little of it up here, simply to avoid a bunch of criticism and arguing back and forth, etc, etc. I even did some of the track testing on another well prepared Pontiac powered vehicle, after taking some criticism right on this Forum that the testing I did was "flawed" being only specific to my own car (which is a bunch of horse crap right to start with)........Cliff
#47
http://www.youtube.com/watch?v=3FfKVVZW1-Y |
#48
very simple test on how to gain some street horsepower, no need to get into apples to apples thingy here...I am pretty sure q-jet will have fare better on that stock iron intake.
many guys do this kind of adaptations and I am pretty sure they are clueless of the HP losses...Good post Mr. Harry..... |
#49
Here is something to think about. The stock steel intake weighs 42lbs while the performer RPM weighs 15. You would need to make 27 more hp out of the steel manifold just to compensate for the extra weight.
#50
Well through all the back and forth on this subject it's a bit confusing for me so I'll ask a more specific question.
If I wanted to install a Holley DP on a performer intake, what type of spacer or adapter should work best? Or should one or the other be used at all? At any rate I am glad for the posted result of the original test. Every little bit of information helps.
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
#51
Another thing to keep in mind if this thread starts to compare the power that the straight up Performer makes when put up with a stock manifold is the fact that Edelbrock states very clearly in there catalog when these manifolds first came is that the Performer is DONE BY 5K rpm.
#52
Guys in case you all forgot the earlier post real world testing WITH an adapter
"As far as adapters-track swap-Brad Urban Carb Shop modified 800cfm 73 SD SR Q jet on an HO intake ported E heads 259@ 0.050 solid roller.Swapped on a Demon(yea one of those crappy things) 850 DP WITH spread bore adapter-idled great out of the box and picked up 0.25 seconds and 3-4 mph."
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
#54
![]() Quote:
![]() Quote:
[IMG] [/IMG]http://www.summitracing.com/parts/edl-2732/overview/
#55
I think your math is off?
#57
Did not sound right to me, 27hp to over come 28lb
#58
WHORE there is another thread cooking on the other side where the math is much apealing for you in there.
"I wanted to stay off Harry K's thread so it doesn't sound like I'm picking on him or being critical of his testing, which I am not" he cant help himself to see someone in this site to show results like a broken record,how many times have we seen this being repeated over & over "The HO intake made 487HP, the RPM made 491HP, the iron intake made 497HP. No spacers of any kind were used during the testing....." |
| The Following 2 Users Say Thank You to harry k For This Useful Post: | ||
#59
![]() I do appreciate you sharing your testing here but man you sure are defensive.
#60
Harry, thanks for sharing your results. great comparison of real world combinations. this will definitely help people make a more informed choice.
| The Following User Says Thank You to Matt Meaney For This Useful Post: | ||
