Old 12-30-2013, 10:39 AM
woogie0004 woogie0004 is offline
Default 70 81 trans am parts long list
pick up in davison mi 48423 or i will ship payment must be us money postal order or paypal some of the larger items i would prefer not to ship but if your serious and understand shipping on large items is going to be expensive i will consider it if you have any question email me at [email protected] or call/text 810 962 4569 most parts came from 77-81 cars unless otherwise noted i have about half of these parts listed on ebay i can send pictures via text or email but i will not play the game of sending 1000 pictures sorry ive had to many people waste my time doing this
75-81 passenger side seat track 75 dollars 18 available
75-81 seat track set 220 dollars 6 available
71-74 passenger side seat track 125 2 available
71-74 seat track set 300 dollars 3 available
Door hinges with new bushings and pins installed 70 dollars a set 2 available
Fischer t top bags 80 dollars per pair 2 pair available
Pontiac motor mounts 80 dollars per pair 6 available
Pontiac thermostat housing 5 dollars each 13 available
Pontiac rocker arms 5 dollars each 20 available
Pontiac power steering bracket 350-455 50 dollars 7 available
Pontiac oil filter adapter 50 dollars 6 available
Pontiac 301 power steering bracket 25 dollars 2 available
Pontiac Push rods 2 dollars each 20 available
Pontiac Timing tab 20 dollars 3 available
Pontiac starter wire tube 15 dollars 6 available
Power steering pulley 20 dollars 17 available
Pontiac water pump pulley 20 dollars 13 available
Pontiac crank pulley 20 dollars 11 available
Pontiac alternator bracket 40-100 dollars many different styles available
Throttle cable bracket 20 dollars 4 available
Pontiac dip stick 20 dollars 1 available
Pontiac distributor hold down 10 dollars 6 available
301 turbo intake 50 dollars 1 available
301 turbo valve cover 60 dollars per pair 1 pair available
301 turbo dip stick 20 1 available
301 turbo valley pan 60 dollars 1 available
301 turbo cable bracket 25 dollars 2 available
Pontiac flex plate 40 dollars 1 available
Pontiac fuel centric 40 dollars 3 available
Pontiac exhaust manifold heat shield 40 dollars 1 available
Edelbrock performer RPM intake NEW 200 dollars 1 available
70-76 fender to core support brace 40 dollars per pair 1 pair available
Misc. 403 Oldsmobile a/c brackets 25 dollars each 2 available
403 olds crank pulley 40 dollars 1 available
403 olds water pump pulley 40 dollars 1 available
403 olds timing tab 20 dollars 1 available
403 olds alternator bracket 40 dollars 1 available
403 olds motor mounts 80 per pair dollars 1 pair available
Small block Chevy motor mounts 40 dollars per pair 4 pair available
Small block Chevy a/c brackets 100 complete set 1 available
Small block Chevy a/c brackets 30 dollars each 6 available
Pontiac oil pan 60 dollars 6 available
74-78 taillights 100 dollars per set 2 sets available
79-81 taillights 300 dollars per set 3 sets available
Seat backs 50 dollars each 9 available
Pontiac valve covers 60 dollars per pair 2 pair available
Fender cut outs with extractors 100 dollars per pair 2 pair available
Core support brackets 20 dollars each 10 available
Shelf 2
71-73 seats complete set need recovered 200 dollars 1 available
70-73 rear valance 100 dollars 2 available
70-73 front valance 150 dollars 2 available
Non a/c blower motor housing 50 dollars 2 available
400 turbo transmission cross member 100 dollars 2 available
4 speed or 350 turbo transmission crossmember 60 dollars 3 available
Intermediate shaft 75 dollars 4 available
Visor mounting brackets 10 dollars each 25 available
Windshield trim chrome 50 dollars a set 4 sets available
Rear trim 75-81 50 dollars a set 2 sets available
70-74 rear window trim 150 dollars a set
70-76 drip rail trim 100 a pair 2 pair available
Shaker ring 40 dollars 2 available
Fan with clutch 30 dollars 1 available
Fisher t top latches 60 dollars a pair 1 pair available
Remote mirror bezel 10 dollars 3 available
Tilt lever 10 dollars 2 available
Fischer t top latches 60 dollars a set 3 available
Rear ash tray 10 dollars 10 available
Power window switch 30 dollars 3 available
Power lock switch 15 dollars 15 available
Gauge rings 35 dollars a set 5 available
Lighter nut 10 dollars 10 available
Large gauge rings 5 dollars each 10 available
Sill plates NIB 40 dollars a pair 2 pair available
Torsion trunk rods 50 dollars a pair 3 pair available
Black windshield trim 50 dollars a set 5 available
75-81 black rear trim 50 dollars a set 5 available
74-76 coolant jug 75 1 available
Power window boots 25 dollars each 12 available
Power window/lock wiring 60 dollars 1 available
Hurst 4 speed shifter 200 dollars 1 available
Remote mirror 80 per pair 1 pair available
8” snowflake refurbished 77-78 SE rim 500 dollars per set 1 set available
8” snowflake rims 400 dollars per set 1 available
Reverse lock out auto 60 dollars 4 available
Revers lock out cup 15 dollars 3 available
Reverse lock out swivel 25 dollars 2 available
Trans cable bracket 15 dollars 2 available
Trans gear selector bracket 15 dollars 5 available
74-76 coolant jug bracket 50 dollars
Crossmember bracket 25 dollars 5 available
Converter bracket 60 dollars 5 available
Pontiac flywheel 50 dollars 1 available
Parking brake 25 dollars 1 available
Tail pipe hanger 15 dollars 5 available
Rear end bump 20 dollars 6 available
Pinion bumps 20 dollars 2 available
Trunk lock mechanism 15 dollars 3 available
Shackles 20 dollars a set 1 available
Windshield holds 5 dollars 7 available
Passenger side door latch 25 dollars 2 available
Rear sway bar to frame mounting bracket 10 dollars 17 available
Rear sway bar bracket bar to mounting pad 10 dollars 17 available
Rear sway bar drop link 25 dollars 14 available
Ws6 subframe bars 30 dollars each 16 available
SHELF 3
Glove box door 50 dollars 2 available
Steering column cover 50 dollars 2 available
Center console back plate 10 dollars
Seat belt cover t top 50 dollars per pair
79-81 headlight bezels 10 dollars each 14 available
Cowl screen 10 dollars 5 available
Front backing plates 40 dollars per pair
Cruise control module 20 dollars 3 available
Ash tray 30 dollars 5 available
71-77 arm rest bracket 10 dollars each 6 available
Front speaker bracket 10 dollars
Steering hub 20 dollars each 7 available
Side mirror hardware set 30 dollars 4 dollars
Side mirror brackets 20 dollars a pair 5 available
Side mirror bracket driver side 10 dollars
Side mirror gasket 10 dollars
70-76 heater control bracket 15 dollars each 2 available
80 81 front speaker grills 20 dollars a pair 2 pair avaolable
Rear speaker grills 80 dollars a pair 2 pair available
Hood popper 5 dollars each 9 available
77 air intake firebird/Camaro 55 dollars
Radiator bumps 5 dollars each 26 available
74 one year only turn signals 150 doll.ars per pair
Hood latch 15 dollars each 12 available
Hood latch 74-76 50 dollars each 2 available
79-81 hood latch cable bracket 25 dollars each 4 available
77-78 hood latch cable bracket 25 dollars each 2 available
77-81 center bumper bracket 10 dollars each 8 available
74-76 center bumper bracket 10 dollars
77-81 side bumper bracket 10 dollars each 7 available
80-81 front speaker brackets 20 dollars a pair
Core support to bumper bracket 10 dollars each 6 available
79-81 core support to bumper bracket 10 dollars each 13 available
Windshield wipers 25 dollars a pair 12 pair available
Windshield wiper arm passenger side 10 dollars
77-81 headlight buckets 10 dollars each 10 available
Horn contact 15 dollars each 8 available
A/c actuator cowl panel 25 dollars each 3 available
A/c actuator kick panel 25 dollars each 11 available
A/c kick panels 80 dollars a pair 3 pair available
Sail panels 100 dollars a pair 3 pair available
Center console 100 dollars each 2 available
71-77 seat backs 40 dollars each 3 available
Rear arm rest 100 dollars a pair 6 pair available
79-81 steering columns 75 dollars each 6 available
70 78 steering column 125 dollars each 2 available
70 78 steering column non tilt 60 dollars each
Hush panel 50 dollars each 7 available
Grab bar 20 dollars each 2 available
Wiper transmission 20 dollars each 5 available
70-73 headlight plates 30 dollars each 10 available
70-73 headlight trim 10 dollars each 5 available
70-73 fuel door 40 dollars
70-72 grill brackets 60 dollars
73 grill brackets 60 dollars
70-74 a pillars 80 dollars a pair
70-73 front bumper L brackets 125 dollars a pair 3 pair available
Headlight buckets 20 dollars each 6 available
Turn signal grill 15 dollars each 6 available
NIB interior screw set 70-73 15 dollars
Taillight housing 40 dollars a pair
Headlight bezels 30 dollars each 4 available
Taillight grills 60 dollars a pair 2 available
73 amber turn signals 100 dollars a pair 2 pair available
70-72 turn signal housing 50 dollars a pair
70-73 turn signal bezels 40 dollars a pair 3 pair available
72 grills 250 dollars a pair
Rear end plates 15 dollars each 12 available
Fender extensions 50 dollars per pair 10 pair available
Inner fender brackets 20 dollars a pair 4 pair available
Leaf spring pocket brackets 50 dollars a pair 3 pair available
Non a/c vents and dash tubes 50 dollars
Gear box cover 2 piece set 25 dollars 6 available
Gear box cover upper shaft cover 10 dollars 3 available
Gas pedal with bracket 10 dollars
Ws6 gear box 75 dollars 3 available
301 turbo air scoop 75 dollars 2 available
Clutch pedals 75 dollars 1 available
Auto brake pedal 40 dollars
Z bar bracket 15 dollars
Marker light bezels 20 per set
Seat belts 125 dollars per set 4 sets available
Visors 30 dollars each 10 available
Headlight switch 5 dollars 6 available
70-76 under sill plate 80 dollars per pair
77-81 under sill plate 80 dollars per pair
77-81 under sill plate passenger side 30 dollars 2 available
Intake tube lower 25 dollars 6 available
Intake tube upper 50 dollars
Radio from 81firebird 50 dollars
Shaker Pontiac 400 125 dollars 2 available
Shaker Pontiac 400 77 only 175
Shaker Chevy 305-350 200 dollars
Dash a/c vents 30 dollars 6 available
Rear defrost switch 25 dollars 7 available
Horn button 30 dollar
Air filter elbow 30 dollars 2 available
Map pocket 30 dollars 9 available
Trunk pop button 20 dollars 6 available
Like new Pontiac starter 15 dollars 2 available
6x heads Pontiac 350-400 50 dollars per pair 2 pair available
79-81 wiring from fuse box up to taillight wiring 15 dollars
79-81 taillight wiring 20 dollars 3 available
301 turbo ecu to distributor wiring 80 dollars
301 turbo a/c wiring 50
Power window/lock wiring wireing 60 dollars 2 available
A/c wiring 30 dollars
Camaro a/c wiring 30 dollars
Non a/c defrost duct 35 dollars 2 available
A/c defrost duct 20 dollars 3 available
shelf 4
79-81 taillight nuts 1 dollar each 90 available
Seat track covers 5 dollars each 26 available
77-81 a/c controls 75 dollars each 6 available
78 Camaro hood latch 30 dollars
Like new grant steering wheel 50 dollars
NIB Pontiac starter 25 dollars
Camaro parking brake 25 dollars
70-77 camaro fuel door 20 dollars
78 rear bumper ends 80 dollars per pair
NIB camel carpet and underlayment 140
Speedo/tak 80 dollars each 3 available
Rear shelf juke NIB 10 dollars
Trunk seal NIB 10 dollars
Brake pedal pad NIB 5 dollars
Gas pedal bezel NIB 5 dollars
Brake pedal bezel NIB 5 dollars
Emergency brake pedal pad NIB 5 dollars
Gas pedal pad NIB 5 dollars
Emergency brake pedal bezel NIB 5 dollars
Chrome radiator support 20 dollars 2 available one is NIB
Core support bushings NOS 30 dollars for the pair
Fan switch NOS 30 dollars
Seat belt loop 5 dollars each 5 available
Brake distribution valve 4 wheel disc brakes 30 dollars 4 available
Hood latch cable 20 dollars
Camaro center console 50 dollars
T top U trim 100 dollars per pair 4 pair avalible
Door handle cups 10 dollars per pair
75-81 a pillars 30 dollars per pair 18 pair available
Camaro fender braces 10 dollars per pair
77-81 fender braces 10 dollars each 26 available
78-81 arm rest 100 dollars per pair 5 pair available
Shifter nob SE gold bird 40 dollars 2 available
Shifter nob Pontiac head 40 dollars 2 available
Shifter nob old school bird like on 69 40 dollars
Shifter nob red bird 35 dollars 5 available
Shifter nob insert red bird 15 dollars 2 available
Camaro shift nob 20 dollars
Non a/c dash bezel bird emblem 15 dollars 6 available
Pulse wiper switch 20 dollars 3 available
Non pulse wiper switch 5 dollars 3 available
Emergency brake release 15 dollars 8 available
Gauge cluster wiring 10 dollars
Water/oil gauge 25 dollars
Fuel/volts gauge 25 dollars 4 available
Door rods 10 dollars 3 available
Plugs for non-power window door 5 dollars each 4 available
Plugs for non-power window body 5 dollars each 5 available
Posi tag 5 dollars
Hood hinges 75 dollars a pair 11 pair available
Trunk popper 20 dollars
Shifter bump style 80 dollars 9 available
Shifter regular 50 dollars 4 available
Non a/c heater controls 100 dollars
70-76 heater controls trans am 100 dollars
Non a/c heater control cables 20 dollars
Jack set up 100 dollars 3 available
Camaro seats blue cloth complete set 150 dollars
Door panel blue Camaro 80 dollars
Pontiac condenser 100 dollars 2 available
A/c suitcase 100 dollars 6 available
A/c duct work 10 dollars each 11 available excluding tube under steering column and behind radio
A/c tube behind the radio 70 dollars 6 available
a/c tube lap duct 70 dollars 5 available
A/c lines 25 dollars
Holley electric blue fuel pump 75 dollars
Door J rods 5 dollars each 7 available
Misc. bolts clips and fasteners .25 to 5 dollars each
Radiator hold ins 5 dollars each 8 available
RTS emblem on dash bezel 10 dollars 3 available
T top trim clips 75 dollars a set 3 sets available
Front seat belt buckles 15 dollars each 3 available
Rear seat belt buckle 10 dollars
75 foglight deletes 30 dollars per pair
74-76 front upper bumper brackets 50 dollars per pair
74-76 front bumper L brackets 75 dollars per pair
80 81 z28 camaro hood air cleaner adapter 25 dollars
74-76 front liscense plate bracket 25 dollars
74-76 front bumper bracket middle 30 dollars
74-76 front bumper to core support brackets upper 20 dollars each 3 available
74-76 front bumper bracket to core support lower 25 dollars per set
78-81 camaro headlight buckets 10 dollars each 3 available
74-76 rear bumper brackets 40 dollars per pair
Shelf 5
Dash bezel 30 dollars
70-74 driver side sail panel 30 dollars
Center console 50 dollars
Lower intake tube 10 dollars
Outside
7” snowflake rims with tires 150 dollars per set
78-81 seat backs 20 dollars per pair
7” snowflake rims without tires 25 dollars each 5 available
8” snowflake rims without tires 75 dollars each 3 available
8” turbo rims without tires 300 dollars per set
Deck lid 40 dollars 7 available
Front sway bar 40 dollars 2 available
70-72 nose 125 dollars 2 available
Core support 100 dollars 4 available
79 rear bumper 50 dollars
74-76 front nose 25 dollars
79-81 front bumper 50 dollars
Passenger side under sill cover 20 dollars
SBC water pump pulley 10 dollars
77-78 rear bumper 50 dollars
Automatic drive shaft 40 dollars 2 available
Manual drive shaft 75 dollars 6 available
Back glass 50 dollars 8 available
79-81 air dam 75 dollars 1 available
A/c heater core housing 20 dollars
Console 40 dollars
Firebird taillights 79-81 20 dollars
74-78 taillights 25 dollars a pair 4 pair available
79-81 rear flares 20 dollars each 1 available
Trans cooler 15 dollars 4 available
Hood hinges 20 dollars a pair
Fan shroud 100 dollars 3 available
Chevy bell housing 50 dollars
Rear spoiler middle 30 dollars
70-73 spoiler ends 60 dollars per pair
74-78 spoiler ends 50 dollars per pair 3 pair available
79-81 spoiler ends 30 dollars per pair 2 pair available
Passenger side toe panel 50 dollars
T top trim 60 dollars
14” rally rim 20 dollars
Shaker hood 75 dollars 2 available
Side glass 20 dollars each 10 available
Gold t tops on y88 200 dollars a pair
T tops Fischer 50 dollars a pair 4 pair available
Inner fenders 30 dollars each 9 available
Cowl panel 60 dollars 2 available
Trunk pocket sheet metal 60 dollars
Leaf springs 100 per pair
Camaro inner fenders 40 per pair
T top roof 50 dollars 2 available
Rear sway bar 40 dollars 5 available
Bins
75 owner’s manual 10 dollars
Pontiac hei distributor 10 dollars
70-72 turn signal housings 20 dollars
Large dash rings 5 dollars 7 available
Cigerate housing dash bezel 10 dollars 1 available
Camaro a/c duct work 10 dollars 2 available
Kick panel actuator 10 dollars 2 available
350 turbo kick down cable 10 dollars
Gas tank strap 10 dollars 2 available
Coolant jug 20 dollars 1 available
Door jamb vents 5 dollars 5 available
Passenger side mirror 15 dollars 3 available
Driver side mirror with remote 25 dollars
Throttle cable 10 dollars 3 available
Trans gear selector cable 10 dollars
Glove box door 10 dollars 1 available
Ash tray 10 dollars
T top trim 15 dollars each 4 available
Front marker light 5 dollars
Horn button center emblem 10 dollars
Fender extensions 10 dollars 2 available
77 chevy 4 speed carb 80 dollars
73 olds 4 speed carb 80 dollars
Steering column cover 10 dollars
Gauge cluster 15 dollars
Carpet guard behind pedals 10 dollars 2 available
Volts and fuel gauge 10 dollars
Windshield wiper bottle with motor 10 dollars 3 available
Windshield wiper bottle without motor 10 dollars 2 available
Glove box insert 10 dollars
Passenger side fender vent 10 dollars
T top handle RH 10 dollars
Old 12-30-2013, 10:58 AM
sd455hota's Avatar
sd455hota sd455hota is offline
PM sent
Old 12-31-2013, 06:50 PM
81transam 81transam is offline
I dont get paid for another week but id be interested in tha few parts. The t top bags those will fit a 81new t top right? The set backs for 20. And then i was wondering do u have a cruise/ turn signal lever for a 8181 ta. Thanks ben
Old 01-05-2014, 10:41 AM
i have a couple sets of t top bags yes they are for the fischer t tops 78 to 81 i do not have a crusie control/ turn signal lever for an 81 thank you, adam
Old 01-15-2014, 09:32 PM
lots of parts still available
Old 01-16-2014, 05:05 AM
A Schab A Schab is offline
Are any of the rear sway bar drop links the early style?
Old 01-16-2014, 11:26 AM
79TA455's Avatar
79TA455 79TA455 is offline
I'm looking for Navy or Dark Blue sun visors. What colors you have?
Old 03-01-2014, 03:17 PM
chaz069 chaz069 is offline
Default 1980 turbo t/a
Do you have any 80 houndstooth dark blue seats? thanks chaz069
Old 03-01-2014, 03:23 PM
Sorry I meant dark blue hobnailcloth seats. Thanks chaz069
Old 03-09-2014, 08:00 PM
TooManyT/As TooManyT/As is offline
Sent you a PM about a cluster housing.
Old 03-27-2014, 08:35 PM
azkeebler's Avatar
azkeebler azkeebler is offline
Default '80-81 air cleaner adapter-shelf 4
PM sent on Air cleaner adapter
2-1962 Lemans convertibles 4cyl, auto
1962 Tempest safari wagon (running project)
1972 455 Formula (tribute)
1962 Skylark convertible 215 4-barrel , auto
2009 G8 Sport red metallic, Onyx leather
Whatever else that make my way into the driveway
Old 03-27-2014, 08:55 PM
Greybeard421 Greybeard421 is offline
PM sent on 71-77 seat backs.
Old 04-01-2014, 08:11 PM
azkeebler's Avatar
Is the air cleaner adapter still for sale? Waiting on your response to email.
Old 04-02-2014, 09:04 AM
pontiac1981's Avatar
pontiac1981 pontiac1981 is offline
Do you have a power antenna that will work in the drivers fender of my 81 TA? Thanks
Old 09-19-2014, 02:17 PM
bankbook's Avatar
bankbook bankbook is offline
79 trunk Corner spoilers still available?
DOC'S TA
Turbo 535, CV 1 heads.
Built by Cerralli Competition Engines
Tenth Anniversary (Van Nuys) restored.
Tenth Anniversary Barn Find (Norwood)
Both 4 speeds!
Old 05-29-2015, 10:11 PM
Pulse wiper switchs? any for 80-81?
[email protected]
Old 06-04-2015, 06:58 AM
firedan firedan is offline
pm sent
