Originally Posted by 70RAlll
I agree..12.25:1 compression seems to be pushing it. Definitely race fuel vs the HO @ 9.9:1 compression could still run on readily available fuel... to me,and disclosure..just my opinion, not trying to start a fight here, I think that is a bit of a stretch. I get the 1.5 increase in compression on all engines from advertised , but when you take an engine from running on pump gas to racing fuel, well I just think you have lost the spirit of STOCK racing.. would love to see numbers of cars with original stock compression engines. Bet the difference ,especially with the RAlll would be glaring... I have always wondered how stock racing produces such numbers vs what these cars did in period tests..And RAlll getting 12.25:1 vs RAIV getting 12:1?? again, seems like the RAlll got a little benefit that makes its performance look better than it ever did against the RAIV,HO or SD's....
Even 9.9:1 is pushing the pump gas limits with a cast iron head and stock HO/SD camshaft. I can tell you I'm at 10:1 with mine and it only likes pump gas if I'm conservative on the timing curve. It's needs a mix of race/pump at the drags.
I know what you mean about the compression and wishing to see stock ratios for stock racing, but as I explained earlier, and as Dennis is also explaining, it's not really possible on a 40 year old engine that's been rebuilt multiple times unless you start changing other dynamics of the engine like installing dished pistons (that don't have good flame travel), or ridiculously thick head gaskets (that kill quench
So now you would be changing other aspects of the engine that will kill performance and again, technically it wouldn't be stock, would it
When you have to overbore, shave heads, shave blocks, all of which are normal rebuild procedures, compression ratios change. Just the nature of the beast. Hence the reason for the allowable change.
