Old 01-04-2014, 07:23 PM
Darth Menace Darth Menace is offline
Is this one of the rear ends that you don't just fill to the bottom of the fill hole? Ive put in the required 3 pints (1.5 quarts) and sticking my finger in the fill hole I can't even feel the fluid yet. Kind of odd if you ask me.
Old 01-04-2014, 07:55 PM
The fluid should be level with the bottom of the fill hole. Fill it until it comes back out & let it settle, then put the plug in & your good to go.
Old 01-05-2014, 01:15 AM
hmmmm, i must have a gto rear end which needs the 4.5 pints instead of the3.0 pints of the tempest
Old 01-08-2014, 07:05 PM
geeteeohguy's Avatar
You can't get straight 80 or 90w anymore. 80w90 is the stuff to use. Use the limited slip additive if you have a limited slip unit. Tighten in a star pattern, like a wheel. Use a short 3/8" drive ratchet and go easy. Just past snug. About 12 foot pounds. Too tight and it'll distort the cover and leak. I have a 3" long Snap-on 3/8" drive ratchet I use for this, as well as trans pans. Works very well. It's a 1/4" drive size ratchet with a 3/8 head.
Jeff
Old 01-08-2014, 10:28 PM
I used the amsoil 75-110. I torqued it to 19ft/lb and there are no leaks which is good. Hopefully it's not too tight, but it's been days and it looks like it's good so far
Old 01-08-2014, 11:00 PM
propuckstopper propuckstopper is offline
Default Right on...
You will be golden with the 75W-110. The SAE spec actually changed some years ago. The new 75W-110 is very close to the old 90 specification.
You'll be good. Spot on, in fact.
