Old 01-25-2014, 04:03 PM
Sloan66's Avatar
Sloan66 Sloan66 is offline
It is a single.
Old 01-25-2014, 06:18 PM
Maybe someone else will chime in but its my opinion that it sounds like the master. And with a single master, you cant be too careful.
They are cheap and easy to replace. If you don't know how old it is, Id replace it regardless. My opinion
Old 01-25-2014, 06:39 PM
GT182's Avatar
GT182 GT182 is offline
Better off to change over to the dual master cylinder. Pontiac smartened up and did for 67.
I had a rear brake line fail on my 66 and it was a bitch to stop. Thank God I had the 4 speed. When I go to front disc brakes the single will be changed to a dual.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 02-02-2014, 05:55 PM
gtos4ever gtos4ever is offline
It wasn't that Pontiac smartened up but rather a Federal mandate, along with the 4way flashers, seat belts, and energy absorbing steering column.
Old 02-02-2014, 10:42 PM
GT182's Avatar
True as stated. But... 66 GTOs had the option for the 4way flasher and shoulder belts before the mandate. My first 66 GTO had shoulder belts in it from the factory and the 4 way flasher unit too. I'm probably wrong but wasn't 66 the first year for these 2 options? I've never seen a 65 with either one installed. And the Restoration Guide says nothing about 4 ways until 67..... nor does the 66 Service manual as far as I could see.
Gary
