Old 01-25-2014, 05:23 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Originally Posted by grandville455 View Post
Paul, Does that mean one wouldn't have to spend the extra money on a tit retainer then if using the beehives?
The Ti retainers are nice, but the steel retainers for Beehive springs are very small and much lighter than the steel retainer for a conventional spring. The steel retainer for a Beehive spring, I would say, is pretty close to the same weight as a Ti retainer for a conventional spring.
Also, I failed to mention that the Beehive spring setup was about 10 lbs. less on the seat, and IIRC, about 350 over the nose.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 01-25-2014, 05:36 PM
grandville455's Avatar
Was that a comp beehive spring?
Darby
M/T 275/60 ET SS Drag Radial
Old 01-25-2014, 07:35 PM
gtofreek's Avatar
Yes. I forget the number, but it was the big one for BB Chevy. I believe it is the biggest/strongest available from them.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 01-25-2014, 07:55 PM
The only one that looks close to your 350 open is the 26120 with 388 open, 370 rate and a 1.900 IH @148, I like that one too, but its only good for 600 lift which would work for me since I run just under that with lash, but no room to grow in lift.
Darby
