I'm looking for an original AC sending unit. It can be used or nos. please let me know. [email protected]. Thanks Imran
make sure you get an 80 lb.....other lines use a 60 lb..looks identicle..but stamped 60
Mark.. The Goat whisperer "I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
I have one off a 68 don't know if this is what your looking for same ?
Peter Serio could tell you for sure, but I believe it would be the same as the one he told me to buy for my 67 GTO.
It was a Carquest unit and tested exactly right. Can't find the part # just now, but will keep on looking. Last edited by Old Goat 67; 01-26-2014 at 11:49 AM. |
thanks 1966geeto can you send me a pic of it, my email is [email protected] or tex me at 905 414 7373 Imran
I asked Scott and he said he would get me the part#
also, watch out, the buick and oldsmobile have a diff threads..68 gto should be right...
GTO Chevelle Camaro and truck seem to all be right numbers..
Found that sender info.
| The Following User Says Thank You to Old Goat 67 For This Useful Post: | ||
Great information, thanks
63 Z-11 JACKSHAW CHEVROLET CAR 67 PLUM SAFARI WAGON 68 ROAD RUNNER HEMI 4- SPEED 69 RA V JUDGE 70 RA III 4- SPEED CONV. GTO 73 FIREBIRD 98 MUSTANG CONV 05 LEXUS SC430 CONV 08 LEXUS ES350 15 SILVERADO |
I made this little adapter set-up from pieces I bought at Lowe's Home Improvement center, as I recall, for around $10 or $15. (I may have had parts of it laying around here already.)
Basically any old used oil pressure sender can be tested and should be before you put it back on your car. I used air pressure to simulate the oil pressure and then measured the results with my ohmmeter. Old senders for a car with factory gauges are prone to failure. They will go bad usually in 1 of 2 ways. Either the rubber diaphragm stress cracks and/or ruptures and then it will leak oil. That or the variable electrical resistance cam and wiper assembly will simply wear out and fall apart. In some cases it will go "open circuit" In another failure it simply has a reading which is way off (in ohms) from what it should be at a given pressure.
Peter Serio Owner, Precision Pontiac |
I LOVE simple!
How close does the carquest oil senders look to the originals?
Night and Day.
