The valves are sitting fairly low in the seats. Pour the chamber full of laquer thinner and see how quickly it leaks out, I'm betting it's gonna run,
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
Hi,
last picture, the one with the piston down in the bore, at the 6 o'clock position of the cylinder wall, what is all of that discoloration that can be seen? In the picture with that piston up, it looks like there is a nick in the piston at the 3 o'clock position. It not very big but indicate a problem below it. 'hard to scrutinize the condition of things without being there and running a finger over it. Going back to the compressed air test you did, your sure that you heard the air hissing out of the crankcase on #8? If so look closer and verify the head gasket did its job by sealing all the way around the cylinder on both the head and block. Please let us know what you find. |
It looks like one of the valves in the first Pic has a hole in it? Or is that just something on it?
The RH piston in the 4th Pic also has marks on it as if something got into the chamber and rattled around for a while. You could have a bent pushrod in that one. Roll them on a flat surface to tell. Then, as mentioned, the one looks like there is some scoring on the wall of it but could just be goo running down it. A couple of things to check there.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress 2005 GMC L-33 |
Looks like a choke screw got into mine on the wagon. Bent 2 pushrods. Did not check compression or if I did, I don't remember what it was. Ran fine.
I wouldn't bet my life on it, but I was pretty sure all the hissing I heard was coming from the crank case. |
