Old 01-29-2014, 06:56 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Default Cam timing question
So before I go about assembling my engine this weekend I have a question about installing the timing set. I've done some reading but apparently nothing is clicking lol my new timing set has the adjustable crank sprocket (+ or - 4 degrees.) I'm wondering if I should install my cam dot to dot, or should I advance it? Here are my engine specs and cam card:
69 YD 400
Std bore
Stock bottom end
Cast #46 heads with screw in studs and new springs, locks, and retainers for the cam
Lunati 268/276 cam
Borg Warner ST10
3.55 rear gears
Here's a link for the cam card:
http://www.lunatipower.com/CamSpecCa...rtNumber=60903
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 01-29-2014, 07:32 PM
Cliff R's Avatar
Cliff R Cliff R is offline
The camshaft should be degree'd to 106 ICL per the manufacturers recomendations.
It is NOT a good ide to simply advance the cam and put the engine in service. Degree the camshaft with the timing set dot to dot and compare to the manufactures recommendations, then move it if/as needed to get it to 106ICL or very close to that number.
This is an area of engine building that should get considerable time to make sure it is right. I see WAY too many folks having all sorts of issues, including not making nearly the power they think they should be, and it starts with putting the cam in the correct position during engine building......Cliff
Old 01-29-2014, 07:36 PM
67gtospud's Avatar
Alright, this is exactly where I get confused. So put gears dot to dot, then check cam per specs correct? Then how do I set it at 106 ICL?
Old 01-29-2014, 07:47 PM
leeklm's Avatar
leeklm leeklm is offline
This is where you purchase a cam degree wheel and read a few articles on how to degree a cam...
The other option is to install the timing set "dot-to-dot," and see how it runs. If you are happy, all is good. If it feels like you are missing low-end power, you could move the crank gear to the 4 advance mark. If you are missing top end, you could move the crank gear to the 4 retard. Of course this trial and error method creates more work, and you are only guessing at this point.
Old 01-29-2014, 08:20 PM
67gtospud's Avatar
I've been doing quite a bit of reading on it and haven't found much on setting the cam on the ICL. I will be ordering a degree wheel this week
Old 01-29-2014, 08:38 PM
67gtospud's Avatar
Can I secure the degree wheel to the crank using the crankshaft bolt?
Old 01-29-2014, 09:41 PM
Motor Daddy Motor Daddy is offline
Do you understand this diagram? If not then you need to learn it so that you understand what you are doing when you degree that cam.
What you are trying to do when you degree in the ICL with a degree wheel is install the cam in such a manner that the max lift of the intake occurs at the proper point in relation to TDC. In the above example the ICL is 106 degrees. That means the max lift point of the intake occurs 106 degrees after top dead center (ATDC).
Simply installing the timing set dot to dot doesn't ensure that the ICL will be at 106 when you check it.
You could have it dot to dot and check it and it could be 102. That means the cam is already advanced when the timing set is dot to dot. If you didn't know that and went ahead and installed the timing set using the 4 degree advanced position (and the timing set was indeed 4 degrees advanced as advertised, which is another can of worms) then the cam would be installed 12 degrees advanced at 98.
If the cam in the pic was installed "straight up" the cam would be installed on a 110 ICL, because the LSA of the cam is 220 degrees. If you place TDC in the middle of the two max lift points then TDC would be 110 degrees away from each max lift point, or installed "straight up." Since 110 would be the straight up position, 106 would be 4 degrees advanced, 102 would be 8 degrees advanced, and 98 would be 12 degrees advanced for a 220 LSA cam on a 98 ICL. You never know unless you check.
The Following 2 Users Say Thank You to Motor Daddy For This Useful Post:
Old 01-29-2014, 10:47 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Like Cliff said, it is very important to get the cam where it needs to be. This is especially true with the VooDoo cams as their lobes are offset from their centerline. That cam needs to be installed no later than 106° ICL.
Now, if the key slots are where they need to be, and the gears are accurate, you should just need the timing marks set dot to dot, with the crank gear on the zero slot[no advance, no retard]. These cams have the advance ground into them so you will usually be within 1° of where you need to be. But it needs to be checked afterwards. Don't use the advance slot on the crank gear as that will advance it 8° crankshaft degrees[or down to the 98° ICL area, not good]. If you need to advance it a couple degrees to get it right, you will need to buy an offset cam key. They make them for BB Dodge engines.
Under no circumstance do you ever want to retard one of these VooDoo cams. They will be a turd. Their design needs to be advanced the full 4° if not 6°. Harold told me to install these cams anywhere from 4°-6° advanced and your good. I have used this same cam before and may have the lifter rise written down at the correct degree at work. That would help a lot to see if your close to where you need to be if you don't have the degree'ing equipment. Obviously, if you can degree it, that's what you want to do. The lobe offset is one of the reasons these cams work so good, so that's why it's so important to get it as close to 106° as you can.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
The Following 3 Users Say Thank You to gtofreek For This Useful Post:
Old 01-29-2014, 10:59 PM
67gtospud's Avatar
So what your saying is install dot to dot and degree the cam, if everything is correct with the cam having 4 degrees already ground in and the keys are lined up as they should be everything should match up to the cam card?
Old 01-29-2014, 11:15 PM
gtofreek's Avatar
Correct, as far as ICL goes. You can't go off the open and close events on the card as the card is a computer generation, assuming a centered lobe. These lobes will vary a little bit on the opening and closing points, so that's why it's best to degree using the ICL method and not the opening and closing points.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 01-30-2014, 12:44 AM
Verdoro 68's Avatar
Timely thread for me.
Paul, in your experience with these cams are they generally off by a common amount? I'll be installing a 60902 with the engine in the car and the heads on. I had planned on installing it +4 via the timing set figuring that will get me close enough but if you've found that each cam is different then I may come up with a plan B.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 01-30-2014, 02:44 AM
gtofreek's Avatar
I was specifically speaking about VooDoo cams. I have seen cams all over the place. The worst needing to be retarded 6°, to make it 4° advanced. That's why it's always best to degree them. As far as the cam card on the VooDoo's, they are usually off a degree or two, depending on their size, from what the card says. This is not a cam grind issue, but rather the computers inability to compensate for the non-symmetrical lobe.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
Old 01-30-2014, 09:26 AM
Most of the time, it's the timing set (gears & chain) that are off, not particularly the cam.
Old 01-30-2014, 10:12 AM
67gtospud's Avatar
From what I understand; you need to know if there is any advance already ground into the cam. If there is and you advance an additional 4* then the timing will be advanced more than you probably want
Old 01-30-2014, 10:37 AM
67gtospud's Avatar
Do I need a crankshaft socket to hold the degree wheel on or will the crank bolt suffice?
Old 01-30-2014, 10:56 AM
Lee's Avatar
Lee Lee is offline
You CAN use the crankbolt, but the crankshaft socket makes it SOOOOO much easier/faster/accurate.
Many years ago, I got the basic CompCam "kit", with the small diameter wheel. I used the crankbolt, and made it work. Sometimes if I tried to turn the engine CCW instead of CW, the bolt would loosen, which made the wheel move - had to go back and re-zero the wheel. It is also hard to get the wheel PERFECTLY centered, as the hole is bigger than the bolt.
I modified the wheel, cutting holes that would allow me to bolt the wheel to the damper. That made the wheel lock in place more solidly, but then the crank bolt was just partially threaded in, and you still can't go CCW.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 01-30-2014, 11:18 AM
Verdoro 68's Avatar
Right. I have the Voodoo cam one step down from the one you are installing. My understanding is that there isn't any advance ground into the cam but I guess that's why you degree it.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 01-30-2014, 11:31 AM
Lee's Avatar
Lee Lee is offline
I do not think I've ever seen an off-the-shelf cam that did not have some advance ground into it from the factory. The cam card linked in the opening post clearly states that it has 4 degrees advance already in it.
The vast majority of pre-ground cams will come 4 advance. There is nothing magical about that number, it is just a "safe" number that works decent for most customers, and they cam grinders are simply used to setting up their machines for that value.
The Following User Says Thank You to Lee For This Useful Post:
Old 01-30-2014, 11:45 AM
gtofreek's Avatar
Yes, the VooDoo's do have 4° advance ground into them.
What makes degreeing easier is to do it with only #1 piston installed. That way the friction is much less and you can turn the crank much easier.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
The Following 2 Users Say Thank You to gtofreek For This Useful Post:
Old 01-30-2014, 12:08 PM
67gtospud's Avatar
Now another question sorta related to degreeing. . .
On my 400 with the factory crankshaft, what size is the snout? So I can order a crank socket. Comp lists 2 different sockets, 1.225" and 1.385".
Definitely a lot of good, useful information in this thread!
