Do yourself a favor and clean the carb off the car. It's way too easy to drop a screw down the intake and that's the last thing you need right now.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
I did that today and replaced the filter. If the sand like crud in the bottom of the old filter is any indication of the carb, then yes it is dirty. I felt that it ran better, but then again it could be psychological. I took it for a VERY short spin down the street and yes it chugged at times, but never died.I also don't know if it's directly related to the slower throttle response, but the throttle cable seems like there is a lot of play in it, as though it needs to be tightened. This could also be directly related to the gas petal being relatively close to the ground and not as high as I would have guessed it should be. I have no idea if throttle cables stretch, but this could be the case. |
What part of the country are you in Darth? It's almost frustrating to read some of the issues you are having, knowing that most are fairly simple things to someone who knows these cars. It's certainly understandable knowing that you were not 'raised up' around these nearly 50 year old cars...so don't think I'm knocking your ability to handle them. You just need some hands-on help. Some of your engine problems could be more serious but there's no way to judge without someone 'in the know' to put their eyes and hands on the car. I'd like to see you meet up with someone on this sight (or in a local car club perhaps) who could go over the car with you and give you some guidance. These cars are really much more simple to work on and troubleshoot than modern vehicles...IF you understand how they function.
Greg Reid Palmetto, Georgia |
Glad to know though a lot of these can be simple things. I am slowly learning with the assistance of youtube and this forum, but I will glady get someone to do a bit of work if I can't. |
