I have a custom ground cam that I bought off somebody else with no paperwork on it. How would I go about finding what ICL to set it for? I don't even know what manufacturer it came from. It's a hyd roller, 230/[email protected] and a 110 LSA.
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
If you have drag radials and a good suspension, I'd install the cam advanced 4. With so-so traction maybe +2 or straight up. With poor traction I'd go straight up, possibly even retarded 2.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
I haven't run this cam before so I'm not sure what kind of traction issues I'm going to have. I guess I'll just check it and, what's the rule of thumb?, set it 4-6 degrees less than the LSA?
The cam should have a number on it on the rear, and possibly a work order number. Some hand grind the work order number into them. Post that number, someone should be able to ID the make, and with the work order number, you can call the manufacturer and find out what the grind is. Otherwise, you can add it to that grinder stand. .
