Old 02-04-2014, 06:44 PM
Heybuck's Avatar
Heybuck Heybuck is offline
Originally Posted by pggto View Post
I don't think that would be a problem in a 70 GTO as far as sensing a bulb out. You put the red LED in a red lens? I was going to try the bright white.
I ordered a pair of the 60 SMD bulbs, WTH they were only $7 shipped! I'll give it a try.
When I thought I'd try the LED globes, the guy selling them asked me for what car? He told me that the white globes would possibly create a white "spot" when the light was on because the LED globes are so much brighter than standard globes. He suggested using the RED ones. So I did.
One other thing I did was toss out the lousy GM bulb holders and replaced them with some out of an early 60's Ford Falcon. All solid brass and beautifully made. Fit perfectly.
I do have a pair of White ones to fit into the back up lights but I just haven't gotten round to that yet
Ian
To laugh at men of sense is the privilege of fools.
Old 02-04-2014, 06:54 PM
Radman's Avatar
Radman Radman is offline
Here is my LED tail lights in the paint booth. I took the picture using the flash on the camera and you can still see the lights. The brake and turn part of the light is much brighter than the tail light. After Keith's car was rear-ended, I decided to make the back end of my modified car very bright. I used the 1157 LED replacement. I cut them off of the normal base and put them on a breadboard circuit board from Radio Shack. I have 5 bulbs in each taillight. All 5 taillights are on. If not using the turn signals all 5 brake lights light. If using the turn signal, the 2 bulbs on the outside blink, the 3 inside bulbs are still brake lights. One thing with the LED lights. You must get a low load flasher for the turn signal to work.
