E-heads, HP and Tigers heads have made around 2.4hp/cfm the cv1 should be able to match that, right? So 480cfm is 1150hp, 500cfm is 1200hp, what do Bill's heads flow? Also 1150 to 1200hp is between 2 to 2.09 hp/ci which should be more than doable. So Kinlser's min hp of 1150hp seems reasonable
| The Following User Says Thank You to slowbird For This Useful Post: | ||
as the stroke goes up the hp per cube will go down....not always the case. |
You think 2hp/ci is asking to much from a canted valve head, sheet metal intake and two 4's with a 4.750 stroke?
I don't know what the cv head is capable of, but bore limited with longer stroke in the Pontiac format hp per cube will go down. Just because someone is beating their chest with a high hp per cube with a bigger bore than stroke, does not mean they will maintain that level as the stroke goes up. |
| The Following User Says Thank You to J.C.you For This Useful Post: | ||
... i dont have either ...
Can you tell me who has made 2.4 HP / ci with a Pontiac engine? I know of only two who are in that area. Pickett and John Marcella Stan @ 2.4 HP / CI ___CI_________HP 400.0000______960 410.0000______984 420.0000_____1008 430.0000_____1032 440.0000_____1056 450.0000_____1080 460.0000_____1104 470.0000_____1128 480.0000_____1152 490.0000_____1176 500.0000_____1200 510.0000_____1224 520.0000_____1248 530.0000_____1272 540.0000_____1296 550.0000_____1320 560.0000_____1344 570.0000_____1368 580.0000_____1392 590.0000_____1416
J.C.
So as the stroke increases your ci you do not multply the ci by 2.4 to get the HP per ci? ![]() Stan
Stop it, his calculator can not be wrong!
| The Following User Says Thank You to LiL Jack For This Useful Post: | ||
Lil Jack,
Why don't you explain to me what my calculator did wrong? Stan
