Old 02-18-2014, 11:31 PM
Norwood's Avatar
Norwood Norwood is offline
2 is my guess
The Following User Says Thank You to Norwood For This Useful Post:
Old 02-19-2014, 09:34 AM
transam1972 transam1972 is offline
Default 2 left
Originally Posted by Norwood View Post
2 is my guess
....I went to bed early and missed out on all the fun....so only 2 TRANS AMs left...so that must make my car even more rare and desireable...I hope the other is Lucerne blue so it does not clash with mine...
Old 02-19-2014, 02:57 PM
Default DASH
Name:	dash detail.jpg
Name:	dash detail 2.jpg
Name:	dash detail 3.jpg
Name:	dash detail 5.jpg
Name:	dash detail 6.jpg
Old 02-19-2014, 03:04 PM
Default DASH
Name:	DASH PLATE REMOVED.jpg
Name:	dash detail 7.jpg
Name:	tilt column.jpg
Name:	ac and heater controls.jpg
Name:	cluster removed.jpg
Old 02-19-2014, 03:12 PM
Default UNDER DASH
Name:	1972 only shaker switch.jpg
Name:	shaker switch detail.jpg
Name:	fuse box 2.jpg
Name:	1972 455 H.O. TACHOMETER.jpg
Old 02-19-2014, 03:27 PM
Default REAR COMPARTMENT
Name:	rear wheel opening sound deadner.jpg
Name:	rear wheel opening sound deadner 4.jpg
Name:	rear wheel opening soun deadner.jpg
Name:	THM 40 SLAPSTICK.jpg
Name:	kick plate.jpg
Old 02-19-2014, 03:37 PM
Default INTERIOR COMPARTMENT
Name:	GM REPLACEMENT CONSOLE LID.jpg
Name:	rear seat belt 2.jpg
Name:	rear seat divider.jpg
Name:	window frame detail 2.jpg
Name:	window frame detail.jpg
Old 02-19-2014, 03:32 PM
SD73's Avatar
SD73 SD73 is offline
Hey Glenn, I see you've got a resistor on your kick-down switch. I have one too on mine. Other kick-down switches I've seen don't have them. I've noticed that the ones without the resistor open the shaker immediately when engaged, while those with the resistor have something like a warm-up period. Have you or any of the other guys noticed that? Is there a specific reason they were designed this way? I'm thinking the non-resistor type may have been phased in later after the shakers went the way of the dodo.
The Following User Says Thank You to SD73 For This Useful Post:
Old 02-19-2014, 03:55 PM
Default KICK DOWN SWITCH
....I am not sure..good ?...hopefully some one comments...I do have a N.O.S. replacement without the resistor...if I ever get this dodo to fly I can try a swap and see what happens..funny how you have to beat on your car to get the flap to open...1972 was such an improvement over the earlier design...I know there was an early GM memo regarding the shakers and I spoke with an original owner whos 71 needed to go to the dealer under warranty for a non functioning shaker..I put a functioning shaker on my 76 with new GM parts but I never knew how to properly hook it up (that's when I bought that kick down switch)..parts guy did not tell me about all the other parts...any way mine was hard wired with a toggle switch and I put a counter weight set up so it would stay open...of course I had to manually pull it closed...(I know,another of my brilliant ideas)...any way some one stole my entire shaker and dual snorkel at the mall...I ordered another shaker but no air cleaner in 1983...was running the 76 original when car was demolished..thats why I still have that SR that's getting painted Lucerne blue..I can not wait to show it off and my custom touch!!!!
The Following User Says Thank You to transam1972 For This Useful Post:
2manyT/A'S's Avatar
You are LUCKY.......looks like your dash pad is still in pretty nice shape......
Eye Candy......garage band?
Go full screen & turn it UP!
The Following User Says Thank You to 2manyT/A'S For This Useful Post:
Old 02-19-2014, 04:22 PM
Default DASH
...thanks!..yes, extremely lucky...actually 20 + years ago I thought for sure I would replace it when I saw that they were coming out with new ones...yeah right?!..20 + years and they still don't stock them...I have learned to appreciate my original and I cannot imagine the work involved installing a replacement..there was 2 cigarette burns on my original console..but fortunately that was one of the extra parts in a GM box stuffed in the trunk in 1985...since I am upgrading to a deluxe interior I need to add the crash handle...I am still on the fence regarding that?!...I thought one day I would start a thread and ask everyone have they ever seen a deluxe interior where the assembler forgot the dash handle??..then I could explain it missing!!..
