#241
Old 02-19-2014, 03:37 PM
transam1972 transam1972 is offline
Default INTERIOR COMPARTMENT
Name:	GM REPLACEMENT CONSOLE LID.jpg
Name:	rear seat belt 2.jpg
Name:	rear seat divider.jpg
Name:	window frame detail 2.jpg
Name:	window frame detail.jpg
  #242
Old 02-19-2014, 03:55 PM
Default KICK DOWN SWITCH
Originally Posted by SD73 View Post
Hey Glenn, I see you've got a resistor on your kick-down switch. I have one too on mine. Other kick-down switches I've seen don't have them. I've noticed that the ones without the resistor open the shaker immediately when engaged, while those with the resistor have something like a warm-up period. Have you or any of the other guys noticed that? Is there a specific reason they were designed this way? I'm thinking the non-resistor type may have been phased in later after the shakers went the way of the dodo.
....I am not sure..good ?...hopefully some one comments...I do have a N.O.S. replacement without the resistor...if I ever get this dodo to fly I can try a swap and see what happens..funny how you have to beat on your car to get the flap to open...1972 was such an improvement over the earlier design...I know there was an early GM memo regarding the shakers and I spoke with an original owner whos 71 needed to go to the dealer under warranty for a non functioning shaker..I put a functioning shaker on my 76 with new GM parts but I never knew how to properly hook it up (that's when I bought that kick down switch)..parts guy did not tell me about all the other parts...any way mine was hard wired with a toggle switch and I put a counter weight set up so it would stay open...of course I had to manually pull it closed...(I know,another of my brilliant ideas)...any way some one stole my entire shaker and dual snorkel at the mall...I ordered another shaker but no air cleaner in 1983...was running the 76 original when car was demolished..thats why I still have that SR that's getting painted Lucerne blue..I can not wait to show it off and my custom touch!!!!
The Following User Says Thank You to transam1972 For This Useful Post:
  #243
Old 02-19-2014, 04:22 PM
Default DASH
Originally Posted by 2manyT/A'S View Post
You are LUCKY.......looks like your dash pad is still in pretty nice shape......
...thanks!..yes, extremely lucky...actually 20 + years ago I thought for sure I would replace it when I saw that they were coming out with new ones...yeah right?!..20 + years and they still don't stock them...I have learned to appreciate my original and I cannot imagine the work involved installing a replacement..there was 2 cigarette burns on my original console..but fortunately that was one of the extra parts in a GM box stuffed in the trunk in 1985...since I am upgrading to a deluxe interior I need to add the crash handle...I am still on the fence regarding that?!...I thought one day I would start a thread and ask everyone have they ever seen a deluxe interior where the assembler forgot the dash handle??..then I could explain it missing!!..
  #244
Old 02-19-2014, 05:00 PM
2manyT/A'S's Avatar
One of my 73's has the resistor for sure........I'll have to check the other....and a 75 G body,as well.....
Eye Candy......garage band?
Go full screen & turn it UP!
The Following User Says Thank You to 2manyT/A'S For This Useful Post:
  #245
Old 02-19-2014, 06:17 PM
Default 72 SHAKER
....can anyone explain exactly how this works?....all automatics have that switch already...what is its function I forgot...NJSTEVES S.D. Formula was never hooked up when it left the factory and it does something...how & why is it hooked into the shaker??...inquiring minds want to know...
  #246
Old 02-19-2014, 06:31 PM
2manyT/A'S's Avatar
It's actually the kickdown switch...for a TH400 trans (ALL GM cars in the 70's with TH400 got them) and in 72 it doubles as the shaker flap switch....
  #247
Old 02-20-2014, 06:35 PM
Default REAR SEAT CUSHION
Name:	REAR CUSHION 1972.jpg
Name:	REAR CUSHION DETAIL.jpg
Name:	1972 STANDARD SEAT CUSHION REAR.jpg
Name:	1972 REAR CUSHION DETAIL.jpg
Name:	rear seat divider 2.jpg
  #248
Old 02-20-2014, 06:47 PM
Default 1972 JACK
Name:	JACK DETAIL.jpg
Name:	PRINCESS LEAIH INVESTIGATING PART NUMBERS ON A 1972 JACK.jpg
  #249
Old 02-22-2014, 08:22 PM
Default M & H HARNESS INSTALL
Name:	M&H HARNESS INSTALL HORN RELAY.jpg
Name:	M&h HARNESS DETAIL.jpg
Name:	HARNESS INSTALL FIRE WALL.jpg
Name:	HARNESS INSTALL WIPER.jpg
Name:	HARNESS INSTALL.jpg
  #250
Old 02-22-2014, 08:33 PM
Default ENGINE HARNESS
Name:	HARNESS INSTALL FIREWALL DETAIL.jpg
Name:	POS & NEG ROUTING.jpg
Name:	HARNESS AND WIPER HOSE ROUTING.jpg
Name:	HARNESS INSTALL 80 AMP ALT.jpg
Name:	BATTERY CABLE CLIP.jpg
  #251
Old 02-22-2014, 09:11 PM
Default 1972 ENGINE HARNESS
Name:	BATTERY CABLES DETAIL.jpg
Name:	BATTERY CABLES TO BATTERY BOX.jpg
Name:	PASSENGER SIDE HARNESS DETAIL.jpg
Name:	VALVE COVER ROUTING.jpg
Name:	1976 BATTERY CABLE SHIELD.jpg
  #252
Old 02-22-2014, 10:58 PM
2manyT/A'S's Avatar
I'll be doing that on my 72 T/A next week with a "points" harness from American Autowire.....
Haven't done one with "engine in"...for a while.......any tips/trlcks?
  #253
Old 02-22-2014, 11:30 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
true dual
I don't know if the shot of the "Trans Pan" (Post # 55) will show in this post, but I noticed the embossed [ HYDRAMATIC DIV OF ....... couldn't see the rest ] I can't remember if my 71 is like that or not. I don't remember seeing that on my 71 transmission pan. Maybe its there and I just don't remember. Thought it was cool to see. Hardly anybody includes the word hydramatic when talking about these old transmissions. They say Turbo 400 or 400 Turbo...?
Thought I'd ask the parts dept. here. Really was just wondering if it was on all of them or just 1972.
Eddie
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
  #254
Old 02-23-2014, 01:36 AM
....well I started at the fuse block and I will say it worked out nice..hopefully some of my pics show how the harness wire fits behind the space where the windshield washer motor is..then I dropped the wire that runs down to the transmission ...a clip on the M40 secures it...it should orient itself when you then run the wire across the drivers side valve cover..you want the harness to look right up against the fire wall...then I brought that next harness wire to the passenger side and ran that up to the a/c..here is a photo of the wire uninstalled...it will be interesting if these companys are exactly the same as to how they make them..I will say this..the harness fits perfect...no extra slack..one wire did pull out of a connector as if it had not been pinched hard enough...I need to address that( a connector for the washer motor)...other than that it fits like a glove..I posted athread, but no replies yet..I am installing a unitized distributor and this is the correct harness for it...I need to be certain I am hooking up the starter correctly....all of my connectors are idiot proof, in other words they will only go on one way..455 H.O.COM has information on a engine harness install too..I am going to check that out again and compare...my T.C.S. connector has the correct resistor just like factory..important that goes on correctly...in NJSTEVES thread he said he had a 50/50 chance and got it wrong the first time!!...so I need to get it right!!..it should go no problem...took an hour today...and an hour to finish the M40 and a/c tomorrow and hopefully the starter!!!Click image for larger version
Name:	GM saved connector.jpg
Name:	HARNESS CLIP MOUNT   M-40.jpg
Name:	1972 CORRECT WIRE SHIELDING.jpg
Name:	1972 unitzed distributer auto ac harness.jpg
Name:	harness lead ends.jpg
  #255
Old 02-23-2014, 02:28 AM
Default ENGINE TURNED DASH
Name:	chrome bezel before painting detail.jpg
Name:	1972 dash panel with 1970 and 1971 chrome bezels.jpg
Name:	speedometer bezel.jpg
Name:	flat black insert on chrome bezel.jpg
ID:	354094ever since I found out the inserts on the 70 & 71 chrome bezels are black I have been meaning to get them done...one thing though..this cars engine turned dash is unrestored, it really is in unbelievable condition with no yellowing or turning funky..my heater & a/c panel needs to be redone though...I plan on addressing that...
  #256
Old 02-23-2014, 02:34 AM
Default 1972 engine turned dash
Name:	1972 unrestored dash plate.jpg
Name:	chrome dash bezel with black detail.jpg
Name:	gauge bezel detail.jpg
Name:	original gauges.jpg
  #257
Old 02-23-2014, 08:40 PM
Default HARNESS INSTALL
Name:	harness connection on transmission.jpg
Name:	harness routing.jpg
Name:	TCS HOOKED UP ALL NICE AND NEAT.jpg
  #258
Old 02-23-2014, 08:43 PM
SD73's Avatar
SD73 SD73 is offline
I like the look of those bezels. I wish they'd have stuck with them longer.
  #259
Old 02-23-2014, 08:46 PM
Name:	TEMPERATURE CONNECTOR....NOTE WIRE RETAINER ON VALVE COVER.jpg
Name:	ac harness mounting.jpg
Name:	ac compressor connector and ground.jpg
Name:	STARTER CONNECTIONS ON SOLONOID.jpg
Name:	wire detail.jpg
  #260
Old 02-23-2014, 08:58 PM
Default TURBO HYDRAMATIC M 40
Name:	underneath exhaust.jpg
Name:	M 40 TAG.jpg
Name:	AUTOMATIC TRANSMISSION.jpg
Name:	SALEM TOOK A SELFIE.jpg
Eddie
