#261
Old 02-21-2014, 11:57 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Here are some more pics of the block getting ready for engine stand and assembly.
Pics 4 & 5 are putting in the cam bearings with the cam bearing tool.
ID:	353926   Click image for larger version
ID:	353927   Click image for larger version
ID:	353928   Click image for larger version
ID:	353929   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #262
Old 02-22-2014, 12:00 AM
gtofreek's Avatar
More pics.
67Cruiser, this ones for you! See, I removed the oil gallery plugs and cleaned the oil galleries!
ID:	353931   Click image for larger version
ID:	353932   Click image for larger version
ID:	353933   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #263
Old 02-22-2014, 12:03 AM
gtofreek's Avatar
Installing oil gallery plug with a .035" hole, in rear of the right oil gallery, to oil the distributor gear.
ID:	353937   Click image for larger version
ID:	353938   Click image for larger version
ID:	353939   Click image for larger version
ID:	353940   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #264
Old 02-22-2014, 12:05 AM
gtofreek's Avatar
Last ones for now.
Core plugs installed.
ID:	353944   Click image for larger version
ID:	353945   Click image for larger version
ID:	353946   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #265
Old 02-22-2014, 03:19 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Too funny Paul!
Super excited on this end, can't wait to get my shortblock!
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
  #266
Old 02-22-2014, 06:30 PM
Nice crosshatch on the mains, Paul.
Dr. Thomas Sowell
  #267
Old 02-22-2014, 07:47 PM
gtofreek's Avatar
Yeah, I like my hatch with lots of cross in it! Thanks!
What about the cylinders and the lifter bores?
I also rounded the chamfer at the bottom of the cylinders so it doesn't scuff the piston.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #268
Old 03-01-2014, 01:44 PM
gtofreek's Avatar
Here are some more pics. I have been sick to my stomach most of this week so I did what I could at work, but progress was slow for me this week. Feeling a little better now so I should be able to finish it this week. Thanks for your patience!
Got the bearings all prepped. Got the crank and cams polished, cleaned, and ready to install.
In the pics of the back of the thrust bearing, you can see where I lightly scratched the back of the bearing, up next to the flange, with a file to reveal the outside edge that is raised up from the rest of the back of the bearing. This raised area pushes the bearing edge into the crank, and if left untreated, and installed, the outside edges of the bearing surface will be shiny from being jammed into the crank. By filing off the high spots, and getting them even with the rest of the back of the bearing, this rubbing condition will not exist. Bearing life is much happier. Also, with the bearing sitting more flush with the block, there is more surface area to transfer heat into the block, and no open voids, or air pockets to prevent heat transfer.
I like to put a nice cross hatch pattern on the bearing surface as well, to hold an oil film better.
ID:	355027   Click image for larger version
ID:	355028   Click image for larger version
ID:	355029   Click image for larger version
ID:	355030   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #269
Old 03-01-2014, 01:46 PM
gtofreek's Avatar
More bearing pics.
ID:	355035   Click image for larger version
ID:	355036   Click image for larger version
ID:	355037   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #270
Old 03-01-2014, 01:52 PM
gtofreek's Avatar
Here are pics of the crank and cam. The crank had a burr in one of the oil holes. I used a de-burr tool and a fine jewelers file to remove it. I went over all the rest of the oil holes to be sure there was no burr hanging into the oil hole. I then polished the crank and washed it, and brushed out all the oil holes.
Polished cam journals and lobes with 1000 grit wet-dry sandpaper and WD-40
ID:	355039   Click image for larger version
ID:	355040   Click image for larger version
ID:	355041   Click image for larger version
ID:	355042   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #271
Old 03-01-2014, 03:07 PM
Beautiful work. I would expect nothing less coming from you. There are very few machinists today that ensure proper crosshatch in anything other than the cylinder walls. Gotta keep those RAs low.
Dr. Thomas Sowell
  #272
Old 03-01-2014, 11:49 PM
GOAT WHORE's Avatar
Thanks fir my patience, are you kidding me! Thank you for the attention to detail.
Wow Paul, I can't wait to get this thing.
Those main bearings have a long oil slot instead of just a hole, tell us about that, just easier to center over oil passage?
You know it's the fine details like filing the back of that thrust bearing that makes the difference
Thanks again Paul for your attention to detail.
  #273
Old 03-15-2014, 02:52 AM
gtofreek's Avatar
Here's a few more pics of installing main bearings and crank. Should have more pics on Monday or Tuesday.
ID:	356696   Click image for larger version
ID:	356697   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #274
Old 03-15-2014, 02:53 AM
gtofreek's Avatar
A few more.
ID:	356699   Click image for larger version
ID:	356700   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #275
Old 03-15-2014, 04:10 AM
Drag Star Le Mans's Avatar
DAMN! That cam and crank look so good!
DragStarLeMans
  #276
Old 03-15-2014, 09:54 AM
DJ455HO DJ455HO is offline
Hi Paul,
I'm just curious why you don't use the viton rear main seals that are available. Have you had problems with them?
Thanks,
Dan
  #277
Old 03-15-2014, 11:07 AM
gtofreek's Avatar
I use them on after market blocks. The stock blocks sometimes are not concentric in the seal groove and the Viton seals may leak. This engine will be going more than 1000 miles away. I don't want to take any chances with a leaking seal[long way to go to fix it, although I wouldn't mind an excuse to go to Oregon, just not this excuse]. This block was only off a few thousandth's, but didn't want to take a chance. I know this graphite seal won't leak. Installed many of these graphite seals with no leakers yet.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #278
Old 03-15-2014, 11:14 AM
GOAT WHORE's Avatar
Yah baby!
  #279
Old 03-15-2014, 11:42 AM
gtofreek's Avatar
Hey, did you notice the freeze plugs are all in the same direction? Just thought I'd point that out!
ID:	356777   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #280
Old 03-15-2014, 11:48 AM
GOAT WHORE's Avatar
Now you're just showing off Does that mean I will have to index the spark plugs to match the freeze plugs.
