Old 02-26-2014, 10:42 PM
Oldeboy70 Oldeboy70 is offline
Default Intake Manifold Question
Question on this stock intake manifold for my 1970 400. This appears to be a vacuum connection but I don't see what would have been connected here. (right next to the "firing order" text)
Seems like it would make a vacuum leak if it were uncovered.
Thanks for the help.
Old 02-26-2014, 10:47 PM
67gtospud's Avatar
67gtospud 67gtospud is offline
Manifold vacuum connection for the vacuum advance. I removed and plugged mine and used the vacuum connection on the carburator.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/[email protected], .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears
Old 02-26-2014, 10:54 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
It's actually the vacuum source for the Thermac unit(s) on the air cleaner.
Old 02-26-2014, 11:04 PM
My vacuum advance appears to be connected to this unit cylindrical unit (in front of the spring) on the driver's side of the carb.
@ Rocky. That makes sense. However I don't think those have worked in years. Flaps in snorkels seem to be stuck open. (not sure how to test)
If that is the case, should I just plug this off, or just hook up the thermac unit?
Thanks for the suggestions.
Name:	photo 1 (1).JPG
Old 02-26-2014, 11:05 PM
Just cap it off
Old 02-26-2014, 11:11 PM
Thank you
Old 02-27-2014, 07:04 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Just a note on "capping" off vacuum ports. Seems like the rubber they are making the caps out of gets soft and fails pretty quickly these days. I see this ALL the time with carbs sent here, most of the vacuum caps are rotten.
Even a tiny vacuum leak can cause running issues, and bring in unfiltered air into the engine that can ruin the rings. I've been shoving a small amount of RTV into vacuum fittings that I'm not planning on using, then putting a plastic cap over them in lieu of a rubber one.
Most hardware stores have the plastic caps, they are color coded, and hold up to underhood temperatures just fine. I got mine at Lowe's in their hardware section.
Sort of related to this topic, I bought a 2012 Harley Davidson Ultra Limited and it developed a light miss and lean stumble around 5000 miles. I bought a tuner for it, but never could tune out the issues in that range. I then decided to purchase a Scream-in Eagle air filter assembly for it, and when I removed the factory air cleaner, found a vacuum fitting at the top of the throttle body with no cap on it. Nice, sucking all sorts of junk into my engine for a few days, glad I discovered it as soon as I did!
I mixed up some Marine Tex and filled the vacuum port, and put a plastic cap over it, and the engine now idles nicely and no lean off idle stumble........Cliff
