does not get a washer..shoulder bolt only...PM me for details regarding this mess
P.S.... I really do need help regarding this, no joke...photos of 80 amp alt...no rear mounting hole!
Looks to me like I see the threaded hole that's eluding you. In your picture it is in the ~8:30 position and approximately 2" from the center. Maybe this is a sign that you are not meant to have a spacer and bolt and should send it to me since I too am in the hunt for one - hah. Look again and I think you'll find it. Bob |
....there is a threaded hole..although it looks like it was never used...it takes a 5/16-18- 1 3/8 bolt...I made a mistake as my water neck bolt is the correct length, its not 5/16..so I am making progress..thanks for the help....NJSTEVE,thanks for posting those photos..that is exactly what I needed!...thanks!!
I can't seem to find the bolt measurement photo so I will take it again and post it.
thanks to P.Y. MEMBER OL PINION HEAD I have a rear alternator bracket and spacer, the spacer is the same ones used on the power steering pump (available in repo kit for $39,not good MOTORCITY MUSCLE CARS)..I installed the clip where I believe it should go..however that causes the connector to be to short to plug in..I can easily lengthen the connector an inch or mount the clip differently for greater length..plus I am still hunting down hardware..it seems wherever a regular washer goes, I got a lock washer instead..I have measured every bolt and it matches the assembly so far..as for lock washers its probably whoever assembled it..as all parts are similar in the general vicinity..I know, complete madness..
