auto/4 speed transmissions and honeycomb/rally wheels were added cost options on Formulas so they are supposed to show on Formula PHS docs.
'72 Formula 455HO TH400, Revere Silver, black deluxe '74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe |
Got it so the no charge was only a Trans Am thing. Thanks
ANDRE 1972 TRANS AM , UNDER RESTORATION http://forums.maxperformanceinc.com/...d.php?t=656067 1972 FIREBIRD FUTUR PROJECT http://forums.maxperformanceinc.com/...d.php?t=674551 1978 TRANS AM (PARTS CAR) MAYBE ![]() 1971 LEMANS T37 (PARTED OUT) ![]() 1976 TRANS AM (PARTED OUT) ![]() 1984 6000LE (SOLD) 2003 SILVERADO 1500 |
I have AMES repop lugs with caps and they are fine...I even saved 1 original as a lucky charm...this FORMULA that's posted, did the standard alternators get a rear bracket..or just 80 amps? thanks!
Yes, but the standard 10SI alt used a different rear alt bracket with PS than did the 27SI (80 amp) set-up.
I was trying to determine if this car has the rear bracket or not?...I mean, who doesn't have a rear alt. bracket??!... I still will never know the truth about my car...the rear alt . bracket bolt hole appears never used..unless the funky corrosion the alt. housings get covered up the signs?..wishful thinking it was inadvertently left off at the factory...it is the original alt...most likely not put back when SR engine was installed...
I know its difficult to tell, but does that look to be original Honeycomb paint?...I got these as I prefer them to Rally IIs..thanks!!
The MSRP is up there! $2,500 in options alone...Not many expensive options missing? That car is loaded for speed and comfort.
Not good for honey wheels. As the red center lugs are anything but wrong.
Mike/Illinois Last edited by Judge273; 03-17-2014 at 08:55 AM. |
