#61
Old 03-16-2014, 05:16 PM
Then what does the term tunnel port refer too? I must be ignorant..
  #62
Old 03-16-2014, 05:35 PM
J.C.you's Avatar
J.C.you J.C.you is offline
A straight port, nothing more, nothing less. That was the advantage of the tunnel port head over other designs of that timeframe. Evidently no one had tried moving the pushrod out of the port and/or probably did not have the supporting hardware to move it.
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #63
Old 03-16-2014, 05:46 PM
So what rpm does ur motor peak at?
  #64
Old 03-16-2014, 06:32 PM
J.C.you's Avatar
CSA determines peak among with other factors including stroke, which I am sure you are aware of. The motor we are still working on is a class motor, built for a specific purpose, hopefully to have an advantage with current rules in that class. I don't think it is a fair assumption that because this engine currently peaks at 8100 or so means a shorter stroke build would do likewise.
I see no reason one could not take a 3.5 stroke or so with a 4.5 bore, a short valve v head such as Lynn's with the pushrod out of the port, move the cam lobes and lifter bores to straighten the angles and make power to 10k.
Would it make comparable power as a symmetrical port head? No, but to blankly say a tunnel port cannot make power past 9200 is not a good thing to publicly post. You may have to eat a cyber post.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
  #65
Old 03-16-2014, 06:42 PM
mike leech's Avatar
mike leech mike leech is offline
I wonder how that would taste?
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
  #66
Old 03-16-2014, 06:43 PM
So how much offset do you have on the intake side..im going to guess enough to force a move on the exhaust side..?? You think you can move the lifter bore enough to straighten out the valve train to a point were the valve train is stable at 10k? I dont think so..I stand by my post. I think you will end up with a pile of broken parts..im guessing you will launch push rods through the hood..Jmo
  #67
Old 03-16-2014, 06:45 PM
I wasn't basing my statement on what your motor peaked at, just curious.. would u feel comfortable turning your valve train to 9500?
  #68
Old 03-16-2014, 07:48 PM
J.C.you's Avatar
It wasn't designed to go 9500. 8500 is enough to kick some arse, if we want to twist it that much.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
  #69
Old 03-16-2014, 07:51 PM
HaHa hayagot a racecar?
Seriously Mike that deserves a Doubleclick Link. not gonna do. nooot gonna doit.
  #70
Old 03-16-2014, 07:53 PM
J.C.you's Avatar
That was the G rated version. I could have said cyber sheite.
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
  #71
Old 03-16-2014, 07:54 PM
mike leech's Avatar
Seriously mike that deserves a Doubleclick. not gonna do. nooot gonna doit.
If I say yes, are you going to post one of those butthurt songs?
EHTTFMF!
  #72
Old 03-16-2014, 07:55 PM
mike leech's Avatar
I'm not at all curious how that might taste.
EHTTFMF!
  #73
Old 03-16-2014, 08:10 PM
So how much offset? Was I right it was so much t forced a move on the exhaust ?
  #74
Old 03-16-2014, 08:22 PM
J.C.you's Avatar
Scott, everything has been moved in some manner. We run a smaller exhaust valve, because of the good flowing convertible exhausts and moved it over in the chamber,.... in turn Tony was able to put a 2.4 intake in the head without shrouding. Are you doubting Tony's ability to make a valvetrain stable enough to stay together?
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
  #75
Old 03-16-2014, 08:33 PM
You said yes. This DCK is for you: http://m.youtube.com/watch?v=2OBV3PfX3BQ
Is it 5 months to Norwalk?
  #76
Old 03-16-2014, 08:46 PM
http://m.youtube.com/watch?v=RwK9ncm...ature=youtu.be Back to topic.
  #77
Old 03-16-2014, 08:52 PM
Im not doubting Tony's ability to do anything.. I am however doubting your ability to answer my question. I never said your engine would come apart, I said that your valve train would not live at high rpm. So is it an "1 or more offset and would u feel comfortable with 10k rpm on that valve train? Also, what tunnel ports besides yours have the push rod outside the port?
  #78
Old 03-16-2014, 09:25 PM
J.C.you's Avatar
What difference would it make if it is 2"s of offset? It is working at the rpm it is designed for. Are you calling 8500 a low rpm motor? lol.
I never said this setup would work at 10k rpm. I said 10k rpm could be attainable with moving things around on a SMALL ci motor. I assumed you would know that csa could be played with and a smaller port designed, thus less offset, cam lobes moved, lifter bores moved, etc.
An unrelated question, besides talking in circles, and a legit one.... how come your flopper ran 1/2 second slower in your possession than it does now with a less aero body?
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
  #79
Old 03-16-2014, 09:40 PM
mike leech's Avatar
4 1/2 months
EHTTFMF!
  #80
Old 03-16-2014, 10:14 PM
Originally Posted by Pont428 View Post
I have heard McCarty Racing is doing a 406 and it should be in the range of 2.7 to 3.0 HP/CID. It has a 4.40 bore and 3.3 stroke. I think that comes out 404 and change. They intend to run NHRA Comp Eliminator or at least Super Stock Modified. I saw the crank, man is that thing cool! It is an old original RAV forging from a 366. They have two of them!
The same crank forging was used in the Butler/Welter 440 cubic inch Twin Turbo and later 106mm single turbo engine. A very good forging.
How many do you want? The Butler/Welter 366 forgings came from my stock.
Tom Vaught
