Old 03-20-2014, 01:46 AM
gtofreek's Avatar
gtofreek gtofreek is offline
Here are some pics of the timing chain set. It is a Roll Master, and it fits nice and snug. You can see there is very little deflection when I push on the chain. Cam is degreed to 107° ICL, where Comp Cams recommends installing it. Found that the 2° incremental keyways in the crank gear, only changed the timing 1/2°. When installed straight up, it came out at 108.5° ICL. I had to use the +6° keyway to gain that 1 1/2° I was looking for. AT 107° ICL, the cam has .073" lifter rise at TDC. That equates to .120" theoretical valve lift at TDC with 1.65 rockers.
ID:	357359   Click image for larger version
ID:	357360   Click image for larger version
ID:	357361   Click image for larger version
ID:	357362   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
