#281
Old 03-15-2014, 11:54 AM
gtofreek's Avatar
gtofreek gtofreek is offline
I'd expect no less!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
  #282
Old 03-17-2014, 11:44 PM
GOAT WHORE's Avatar
GOAT WHORE GOAT WHORE is offline
Got to work in the car a little this weekend. We were installing the trim to make sure everything fits right, well here is one piece that did not fit well. We tried three different ones and they all fit the same. Does not look so bad in this picture but it was.
1969 GTO 4spd. Antique Gold/black, gold int.
1969 GTO RAIII 4spd. Verdoro Green/black, black int.
1969 GTO 4spd. Crystal Turquoise, black int.
1970 GTO 4spd VOE Pepper Green, green int.
1967 LeMans 428 Auto. Blue, black int.
  #283
Old 03-17-2014, 11:48 PM
GOAT WHORE's Avatar
Here is the finished product. Mike had to just do a little body work to make the fender fit the trim. Believe we are in to making the rear bumper fit the car next weekend.
  #284
Old 03-20-2014, 01:38 AM
gtofreek's Avatar
Here are some pics of the assembly. I like to go over the piston skirts with a Scotch-Brite pad. This does 2 things:
1. Removes any burrs that may have been left behind from machining.
2. Leaves a fine cross hatch pattern on the skirt to help hold oil.
Plus it just looks better if nothing else.
Set ring gaps at .019" top, .022" second, and the oil rails were .024".
ID:	357354   Click image for larger version
ID:	357355   Click image for larger version
ID:	357356   Click image for larger version
ID:	357357   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #285
Old 03-20-2014, 01:46 AM
gtofreek's Avatar
Here are some pics of the timing chain set. It is a Roll Master, and it fits nice and snug. You can see there is very little deflection when I push on the chain. Cam is degreed to 107° ICL, where Comp Cams recommends installing it. Found that the 2° incremental keyways in the crank gear, only changed the timing 1/2°. When installed straight up, it came out at 108.5° ICL. I had to use the +6° keyway to gain that 1 1/2° I was looking for. AT 107° ICL, the cam has .073" lifter rise at TDC. That equates to .120" theoretical valve lift at TDC with 1.65 rockers.
ID:	357359   Click image for larger version
ID:	357360   Click image for larger version
ID:	357361   Click image for larger version
ID:	357362   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #286
Old 03-20-2014, 01:49 AM
gtofreek's Avatar
Here are some pics of the oil pump. Upon disassembly, I found some slight rust spots. The edges of the gear pockets have sharp edges and small burrs on them.
ID:	357364   Click image for larger version
ID:	357365   Click image for larger version
ID:	357366   Click image for larger version
ID:	357367   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #287
Old 03-20-2014, 01:58 AM
gtofreek's Avatar
Here I cleaned everything, deburred the inside of the housing, Sanded and Scotch-Brite the edges. Scotch-Brite the gears, and sanded the cover plate flat on the granite slab. Also sanded the top and bottom of the housing on the granite slab to insure flatness, and also get the cover plate to gear clearance down some since it was just a tad excessive. It had .0025"-.003", and I took it down to .0015"-.002". There was a .0005" difference between the heights of the 2 gears. I removed the 5/8" check ball and installed a 9/16" ball in it's place. I also had to install a 1/16" thick washer behind the spring to get the pressure back to where it would have been. This 9/16" ball gives more room for debris to pass by without jamming the ball open. With the 5/8" ball in place, there is only about .014" clearance for debris to pass by, That's not much room, so the stock size ball tends to get stuck open at times and cause lack of oil pressure.
ID:	357369   Click image for larger version
ID:	357370   Click image for larger version
ID:	357371   Click image for larger version
ID:	357372   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #288
Old 03-20-2014, 02:03 AM
gtofreek's Avatar
The oil pump mounting ears are not flat. How is the bolt supposed to clamp good if it's mount is not flat? Been seeing this a bit too much lately. Had to clamp it in the mill and cut it flat so the bolt would fit nice and flat. Can't believe Melling lets them go out like this. They didn't used to be like this. Makes me wonder if they are casting them in China now. Just saying, maybe.
ID:	357376   Click image for larger version
ID:	357377   Click image for larger version
ID:	357378   Click image for larger version
ID:	357379   Click image for larger version
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #289
Old 03-20-2014, 02:04 AM
gtofreek's Avatar
Last pic. My camera batteries died so I will have to get some more pics tomorrow.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #290
Old 03-23-2014, 10:37 PM
GOAT WHORE's Avatar
Default rear bumper
Got a good day of work in on the rear bumper today! Mike and I used this get up to bend and tweek the bumper back into shape.
  #291
Old 03-23-2014, 10:39 PM
GOAT WHORE's Avatar
Not quite done yet but getting close.
  #292
Old 03-24-2014, 12:33 AM
Well, that's interesting....Are you planning to paint the bumper?
Old 03-24-2014, 12:38 AM
GOAT WHORE's Avatar
Hell no! I plan on putting a kick ass tripple plate chrome job on the deal.
  #294
Old 03-24-2014, 12:48 AM
Yeah...now you're talking. Don't care much for the painted rear bumpers.
Don't the re-chrome places also straighten the bumper for you? That's why I was wondering if you were going to paint it since you guys straightened it yourselves.
Old 03-24-2014, 12:50 AM
GOAT WHORE's Avatar
The place I go to said to make it fit the car before any chrome, makes sence to me.
  #296
Old 03-24-2014, 10:17 AM
Yeah, makes sense.
Old 03-25-2014, 01:01 AM
gtofreek's Avatar
Balancer was out of balance by 3.7 grams. Balanced it down to .5 grams.
Flywheel was off 31.7 grams, now .7 grams. Flywheel was counter balanced before, neutral now.
Forgot to post this last week.
What are you doing for a pressure plate Greg? That should be balanced also.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #298
Old 03-25-2014, 09:48 AM
GOAT WHORE's Avatar
That's funny about the flywheel, believe it was advertised as neutral. Paul, should I just get someone local to balance the pressure plate?
  #299
Old 03-25-2014, 10:16 AM
gtofreek's Avatar
If there is someone you can trust, then yes. You will need the flywheel to do it. Then have them mark it's position on the flywheel.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
  #300
Old 03-25-2014, 10:19 AM
gtofreek's Avatar
If that thing was used as is without balancing, you would look like Gums Magoo in the first block or two after it shakes the teeth out of your head. 31 grams out, 6" off center, is equal to tons at 3-6000 rpm's!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
520-294-5758
