Old 04-01-2014, 11:34 PM
Alvin's Avatar
Alvin Alvin is offline
Lightbulb
The recommended usage info direct from the Mfg. website: http://www.royalpurpleconsumer.com/p...ystem-cleaner/
RECOMMENDED TREAT RATE & USAGE
3,000 MILE INTERVAL – 6 OZ. CAN
Pour entire contents of 6 oz. can into tank prior to fueling. Treats up to 20 gallons. Ideal for two and four stroke engines.
10,000 MILE INTERVAL – 20 OZ. CAN
Pour entire contents of 20 oz. can into a nearly empty tank and refuel. One (1) can treats up to 20 gallons. For tank sizes outside of this range, use one (1) ounce per gallon. In two-cycle engines, use one (1) ounce per two (2) gallons.
Old 04-02-2014, 10:14 AM
Don't forget to ask the salesman whether to add it to the tank empty or full Gary...lol
Seriously, I think they may only be concerned that it's mixed thoroughly. That gas pump will really agitate the fuel in the tank and therefore accomplish a good mixing action.
Old 04-02-2014, 10:33 AM
mess1153's Avatar
mess1153 mess1153 is offline
It does say what Alvin shows, "add to a nearly empty tank". Well either way I had a full tank and I went ahead and added it. I figure it isn't going to hurt anything but it would be more of what Greg said, thoroughly mixed as adding gas will agitate the mixture. It may just not work as advertised or as well.
I added it last night and plan to go cruising a little tomorrow night, so I will see what (if any) difference I feel.
Old 04-02-2014, 11:14 AM
GT182's Avatar
GT182 GT182 is offline
Found out this morning that the sales guy here doesn't carry it. But... he says Sea Foam is better that the Royal Purple.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 04-02-2014, 11:15 AM
mess1153's Avatar
I bet he carry's Sea Foam -
Old 04-02-2014, 11:30 AM
GT182's Avatar
Yeah he does. Funny how you figured that out. LOL
Gary
Old 04-02-2014, 09:09 PM
Reminds me of when my wife and I had a restaurant. People would come in and ask, "What's good?". My pat answer was, "Everything on the menu is good. We decided to take everything that was not good off the menu."
Old 04-03-2014, 01:02 PM
Originally Posted by GOAT WHORE View Post
For which car?
The 1964 Catalina 2 door post sedan I own. Would you like to see the original title? It's the SAME vehicle I spent 12 yrs. trying to title in IN but couldn't. See what happens you believe LIES?
Dr. Thomas Sowell
Old 04-03-2014, 04:15 PM
Will Will is offline
Do some donuts, that should mix things up well enough.
Old 04-03-2014, 08:52 PM
Or ride down the railroad tracks...
Old 04-06-2014, 02:28 AM
Formulabruce's Avatar
Read the first line, and shook my head... while it has some good facts,there are other tools to fix its problems.. and 1979??
QUOTE>>"Ethanol is a 200-proof grain alcohol typically derived from corn. It was first added to gasoline in trace amounts beginning in 1979."<end Quote.
" Long may we DRIVE !"
Old 04-06-2014, 10:26 AM
GT182's Avatar
Bruce, they found out back then it wasn't any good. Then the idiots in our time had to bring it back again. And now they want to make it worse than it was before.
Gary
Old 04-06-2014, 01:20 PM
Yup, you are correct. When we forget history, especially what was NOT good, we are doomed to repeat it..
The article didnt even get into the fact that the whole Corn fuel industry is subsidized..so we all pay.. even though the crap has cheaper prices at the pump and has piss poor fuel economy...
Old 04-07-2014, 03:03 PM
einstein's Avatar
einstein einstein is offline
When I lived in central Florida, pure gas was only available by FL law at marinas and "specialty" shops. Law allowed sale of pure gas for use in vintage vehicles. Of course, no right-thinking capitalist station owner would set up a tank and pump for non-E gasoline, so it was nearly impossible to find pure gas anywhere except marinas.
There was one shop in Longwood (north of Orlando) who serviced RVs and sold custom choppers who sold it, but you carried your cans in and he filled them back in some mystery portal, for $4.49 when E10 was under 3 bucks. We're in CF this week to see family, and that shop is gone replaced by a Tesla dealership. At least I was able to get it for lawn equipment...
Now that I live in Arkansas, the state law allows sale of pure gasoline, so there are a fair number of places where it's available. Premium tends to run 25-30 cents per gallon extra. Was $3.59 in AR for pure gas, $3.29 for E10. Meanwhile E10 in FL is $3.59.
Bears mentioning that most small engine makers will void warranties if they decide your fuel damaged the engines. I learned that in FL at a small engine shop, when I had a Troy-Bilt lawn trimmer throw the rod at 2 hours runtime.
Old 04-07-2014, 03:27 PM
The Valero station down the street sells REC 90 from the normal fuel pumps. A couple of stations in Port St. Lucie do the same. No "sneaking it" around here needed.
Dr. Thomas Sowell
Old 04-07-2014, 08:17 PM
A.W.Dille A.W.Dille is offline
There are a couple of stations in the Mocksville, NC area that sell pure 93 octane gas and one station that sells it in 87. I hate the ethanol, causing all kinds of problems with my 78 Chevy pick-up, had to pull the carb a couple of days ago to clean the mess out of it, and going to have to do again in the morning. And I just did a complete rebuild of the carb about 8 months ago, and have to pull it about every 3 months to clean it out and re-tune. The ethanol messes things up more than you can imagine to where I may have to order carb kits from Cliff on the average of three per carb at least 4 times a year, and that folks will get expensive. Going to try the Sea Foam and see if that cuts down on the maintainance.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 04-07-2014, 09:57 PM
GT182's Avatar
A.W., if they force E15 on us then we're all in for big trouble.
Gary
  #38
Old 04-08-2014, 12:15 AM
Gary, I think that's a "when", not an "if"...........
Dr. Thomas Sowell
  #39
Old 04-08-2014, 07:22 AM
Yes we are. And I'm not about to buy a newer truck. I can't afford it and they aren't built as good as the old ones as far as frames and springs are concerned IMO. With what I have had to go through with getting the wifes car (96 Chevy Corsica) to pass emissions inspections down here I don't want that hassle every year with anything else.
