so in the picture the correct sending unit is on the left I'm going to remove the sending unit on the right what is supposed to go in that hole? and what is the single green wire 4 if its not supposed to go on to a sending unit? I am so confused I just need to hook the temperature sending unit up correctly
Switch on the passengers side is the thermal control switch for the vacuum timing control switch.
T.C.S. system controled vacuum to the vacuum advance when the engine was cold. It was suppose to help with emissions. Newer models used a thermal switch with the vacuum lines plugged directly into it. Got rid of the extra electrical part. It has no effect on temperature sending unit operation. I think the engineers that designed it with the green wire jumping from one switch to the other....was just messing with us. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
Sorry for the confusion JT...
Greg Reid Palmetto, Georgia |
