#441
Old 04-03-2014, 09:10 PM
Bentwheelbob's Avatar
Originally Posted by 70RAlll View Post
Hey Bob.. need more items for your mission creep?? How about the HVAC controls, disassembled they clean up real nice. Many of the control parts need cleaning, filing down the contact points etc.. the vacuum piece is a good candidate for repair with thick grease to ensure it holds vacuum..
Thanks to My Pal Dave this item that Bill kindly added to the MCL has been checked off. The HVAC controls have been pulled, disassembled, cleaned and lubed. I appreciate the recommendation because they were very dirty with 43 years of accumulated grime. MPD did a fantastic job, and despite the fact this will never be seen, there is satisfaction knowing that the controls should be in good working order for much longer than I will be. There is some light haze/scratching on the clear faceplate cover near the word "cool". I'll need to see if this is something that can be removed and polished out, absent a better suggestion from someone on the Forum. Pictures are worth a thousand words, and here they are.
Before:
After:
  #442
Old 04-03-2014, 11:50 PM
70RAlll 70RAlll is offline
Before:
After:
Bob.. two things,.
1.was 1972 the first year defrost was used??I thought 1973 was?? if yours has been replaced, I have an extra de-ice unit
2. I have 2 of the wood grain face plates for your HVAC controls. I think there were two different grain patterns or something like that. PM me if you want one. these are NOS in the old GM wrapping. for some reason always had a hard time finding anyone who wanted these.??.
I guess my "it's easy" comment now makes sense?? That is one item many overlook when doing a clean up/body on restoration. Easy to get out and is a part that always is dirty and needs grease..
glad I could help with the list.. If you'll let me.. I will keep you busy until Christmas lol..
  #443
Old 04-03-2014, 11:56 PM
Hey Bob.. just checked the HVAC faceplates I have.. One is part number 1223318,which my books show as 1972 only F ex TA w/AC.. sounds like it is a 72 only part?? The otherone I have,the wraping is torn up,but I had in a zip lock baggie and had written 70-71 Formula at some point.. Maybe the 72 guys can chime in on what the difference was? If you want it, it is yours..
  #444
Old 04-04-2014, 12:53 AM
transam1972 transam1972 is offline
Default CONTROL
mine says DEFROST...the repop is totally wrong
  #445
Old 04-04-2014, 09:21 AM
Default HVAC Bezel
Well, I'm an idiot. I didn't even look at the faceplate after Dave cleaned the HVAC control up. The face plate photo was the pre-cleaning "file photo". After the generous offers and replies on the faceplate I looked at it this morning, and voila it is perfect. I spoke with MPD this morning and he acted insulted that I would think he would disassemble the control and not polish out the haze. He rocks.
Thanks for the offers.
  #446
Old 04-04-2014, 09:33 PM
Bob.. the parts I have are the woodgrain front piece that attaches to the faceplate. Not the clear piece but the woodgrain metal part.. If you want the 72 only piece let me know..
  #447
Old 04-05-2014, 06:54 PM
Thanks Bill, but the woodgrain on the HVAC controls and dash bezel looks great. It looks like it was replaced at some point and has seen little usage. MPD got the controls reinstalled today. He said it was easier to get them out than it was to put them back in.
  #448
Old 04-05-2014, 07:08 PM
Default Big Day...
Big day at the Hot Rod Garage today. A lot got done. I'm getting ready for the new bumper (old one with new triple chrome) which should be delivered on Monday and wanted to get the bumper guards put together. I purchased a set of triple chromed guards with no bump strips and a set of NOS guards with crappy chrome and perfect bump strips. I switched things around and they look great. I sure hope the bumper looks this good. I sure hope the guards fit the bumper. Here's some pictures:
  #449
Old 04-05-2014, 07:20 PM
The Boss's Avatar
The Boss The Boss is offline
You do nice work!
And go racin' in the street.
  #450
Old 04-05-2014, 07:52 PM
Default Polishing Park Light Lenses
We also got the amber park light lenses polished in anticipation of the valance work. I used the same 3M headlight restoration kit that was used on the taillights, but then I broke out the 3" R/O polisher and the Griot compounds to finish it up. They came out really good, but the right side lens has some rally deep rock chips that were not removed. Regardless, they look much better and I like the fact they appear to be original. These were the one piece units. Here's the before and after.
Boss-Go UConn. However, if they face KY your on your own.
  #451
Old 04-05-2014, 08:05 PM
Bob.. those really look good. great job on polishing..
  #452
Old 04-05-2014, 10:45 PM
Norwood's Avatar
Norwood Norwood is offline
It's the little things, looking good Bob. Those are most likely the best bumper gaurds in the country......
  #453
Old 04-05-2014, 11:23 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Bob, why does one have a PN on the lens portion and the other does not?
My '73 unit has it.
  #454
Old 04-06-2014, 12:05 AM
My '73 unit has it.
HFR - Good eye. Actually it did although it can't be seen in the before photo. In the after photo, it has been pretty much obliterated by the polishing process. The rock pits were so bad on this one that I started sanding with 220 grit, went to 320, 400, 600, 800. 1000 and the 3000. After that I used the compound included in the 3M kit. Once this was done I still wasn't happy so I broke out the 3" R/O and used the Griot machine polish 1, 2 and 3, followed with the Best in Show Wax. On the other one the process was much the same, but I started with 600 grit and sanded much less aggressively since it had fewer deep pits, and tried to be careful to avoid the GM PN's. On the pitted one I didn't try that hard to avoid the part numbers and justified that by the fact that bezel covers that portion of the lens.
  #455
Old 04-06-2014, 12:26 AM
Default Instrument Bezel
While I had the polishing stuff out, I also polished the clear plastic instrument bezel window. I did it much the same as the parking lights. On most of it I started with 500 grit, but on several areas (namely the turn signal indicator windows), I started with 220 grit and worked up. There were several really deep gouges on the turn signal windows that appear as though someone took a pick or punch and gouged out a deep trough. these were very laborious to get out.
Generally I am very happy with how it turned out. It's is far from perfect, but when you look at the before and after pictures the difference is very noticeable. Beyond removing the scratches, it just makes it look much sharper and brighter if that makes sense.
While everything is pulled apart, I am trying to decide whether to replace the bulbs with LED's or 4 watt replacement bulbs. Any recommendations?
We also cleaned most everything back in the inner dash area. MPD removed the wiper switch and prism diffuser and those look like new. He also wiped everything down back there, lubed the speedo cable, and replaced a vacuum line grommet that had come loose. The center stack gauges were also removed, cleaned and the lens polished
Here's a few pictures as usual. Check out the turn signal windows.
  #456
Old 04-06-2014, 01:50 AM
Formulabruce's Avatar
looks great Bob!! wow!
I have not been impressed with the dimming ability of the LED dash bulbs ( 194) and the hue of the color either..cant use them ( 194Led) on front side markers as they dont have enough resistance to make flasher work correctly
" Long may we DRIVE !"
  #457
Old 04-06-2014, 02:55 AM
Bob.. I 2x staying with regular bulbs. Since you have everything out, If it was mine, I would have the clock converted to quartz movement. There is a place on the web that sells a DIY kit for something like $59 and if you send them yours they will do it for you for something like $125 all in. I have done 3-4 of these myself and they are not that difficult. The OEM clock is just a POS and after 45'ish years you will have problems down the road. may as well address this while everything is out?? I am sure others here have similar experience.. your polishing ability is bada$$.. remarkable how clear that gauge face is now.. I bet it never looked that clear when new..
I just looked the clock up.. Now they are $80 and complete deal for $140..Here is a link:
http://www.clocks4cars.auctivacommer...-P3100689.aspx
http://www.clocks4cars.auctivacommer...-P4191885.aspx
If you do a search Rocky did an article in HPP on this very item..
  #458
Old 04-06-2014, 07:31 AM
njsteve's Avatar
njsteve njsteve is offline
There is really no need to convert the clock when it works fine in its original configuration. Especially after I went through all the trouble of getting it working again. :-)
The quartz conversions do not have the constant flow movement of the hands like the original points-style do. They "tick" off one second at a time instead of sweeping along smoothly.
The vast majority of the original clocks do not need anything more than a filing of the points and some minor cleaning of the mechanism with WD-40.
  #459
Old 04-06-2014, 07:33 AM
njsteve's Avatar
That lens looks to be around the same size as the eyeglasses I wore in the 1970's.
No wonder I never could get a date for the prom....
  #460
Old 04-06-2014, 08:33 AM
Norwood's Avatar
That is an incredible outcome on that lens
