#2461
http://sfbay.craigslist.org/sby/pts/4402830601.html
That firebird needs this high horse power motor.
#2462
Looks like a scam or uneducated seller. I see very old heads and 2 freeze plugs in the block. Is that carb looking thing and autolite inline 4 bbl? Plus he says "don't choke his chicken," thats funny right there!
#2463
actually only 6, cause 8 would be just too much. maybe a little corvette influence there?
___________________________________________ the more im around people, the more i like my dogs |
#2464
Ha...I just saw a bunch and didn't bother to count. Given the rest of the car I assumed one for each cylinder! But you are right, 8 would be tacky. 6 is tasteful.
Ken '68 GTO - 464 - Ram Air II heads - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around) '74 Ventura 350 '69 AMC Javelin SST |
#2465
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
#2466
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
#2468
choke your chicken
#2469
1969 Firebird 350 convertible, t-5, Carousel Red 2008 Solstice GXP 5speed manual, Sly 2008 Grand Prix, Ink Slate, Winter daily driver 2009 G8, Switchblade Silver, summer daily driver |
#2470
Those are the old style pistons, I'd bet that's a 326 instead of a 350. I don't believe you can get 350 pistons with the old valve-relief pattern. I wonder how long ago that engine was built.
Rich The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance. Henry Ward Beecher "The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher |
#2472
#2473
He say he has 5K in the bottom end, is there a bag of money sitting in the block somewhere. Those are old style TRW piston that would cost about $ 200.00 a set & I didn't see anything else that was close to the money he's asking. The blower looks to be at least 25 years old.
#2474
Is it me or is the blower sitting on it backwards? If so then that will really choke his chicken, and throw efficiency right out the window. LOL
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
#2475
I just took a second look at that ????? 350 with the blower. WHY would a reputable engine builder use heads with press in studs for a blower engine. You would have to think the first time you wound it up you would pull a few of the studs right out just because of the pressure of the ??? roller cam & valve train parts. 75 years of Pontiac engine building , he would have started out on the flat heads, but if he was doing it now could he even pull the torque wrench to tighten the heads because he'd have to be at least 92 years old now. Thats if he started at 17 years old. Just make ya wonder.
#2476
It's an early block it has 2 freeze plugs aside. I'm pretty sure thats a super duty 326 lol
#2477
Now here's a deal you won't want to miss!
Only $4500! http://detroit.craigslist.org/mcb/pts/4410714280.html
"Keep your stick on the ice...and your head up." 1910 Buick Model 19 Touring 1924 Cadillac 5 passenger coupe 1933 Pontiac 4 door sedan project 1933 Sport Coupe project 1941 Packard 120 coupe - Factory AC and OD. 1968 GTO, 428, THM400, 2.73 posi cruiser 1958 Buick Caballero 4dr hdtp wagon 2018 Ram 1500 to tow stuff 2024 Buick Encore GX Last edited by jmt455; 04-12-2014 at 01:21 PM. Reason: added image |
#2478
Yep, I'm sure everyone is running to the phone right now.
#2479
"Bring a trailer because it will not run down I-45 until the motor is put back in it. One tire is flat as well." http://houston.craigslist.org/cto/4414905057.html
#2480
" 1967 firebird street or strip"
"firebird frame off restoration project. this car has been stripped down and media blasted" http://sanantonio.craigslist.org/cto/4409849851.html Meant that literally,"street or STRIP"
