I have a question about the air cleaner bases to. I have a base that I think it cake from a T/A but not sure. I've had it for a LONG time. It is the typical 16" base with a single snout. The end of the snout is about 3 1/2 inches wide on the end & it has 4 of the vac. hose clips , with the indentation on the side of it (where the dist sits) Has a place for 2 sensors on the inside of the base, 1 is for a sensor with a single hole post, & then 1 with 2 posts , both would come through the base for vac. lines to be attached. Also has the 1/2 or so hole for where the air port on the top of the cabs would come through it. Can anyone tell me what this base should fit. The smaller snout end is what is confusing me. As i said I've had this for a long time & am not sure about it. Any help ?????
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
I'll get a few & have them on tomorrow so you guys can help, sorry for the long winded description but was hoping someone would know from that but I kinda knew I should have had a few pics.
Ok guys here the pics of the air cleaner base that I need help in identifying I have had it for a long time & don't remember what I got it off of. I had it tagged at one time but when I cleaned & painted it , well the tag got blown off in the sand blaster & I need help. Thanks in advance . I don't know if you can tell it does have 3 hols in the side The hole closest to the snout has a hole that looks kinda like a key slot. & it has a baffel in it just inside the snout as in pic 4 . The end of the snout is about 3 1/2 inches wide at the outer end.
Is there a different shot that I can take to give you a better idea of what you need to see which one it is ????
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! Last edited by 2manyT/A'S; 05-05-2014 at 12:27 AM. |
