#561
Old 05-08-2014, 10:21 AM
bird72's Avatar
bird72 bird72 is offline
great and unique car, I like following this thread!
72 Bird
  #562
Old 05-10-2014, 07:06 PM
Bentwheelbob's Avatar
Wow, lots got done today. I have been working to get my jack and spare correct and refinished, and that is done. It may not be totally correct, but it's got to be close, and it is done. 70RAlll turned me on to a place in Colorado that does cad plating and they did a great job. Aero Propeller is the name. Everything else got media blasted, repainted, blah,blah. Norwood supplied the correct J-hook hold down. It looks good. It's off the mission creep list. I am happy.
  #563
Old 05-10-2014, 07:22 PM
....and the doors got wet sanded and buffed out. Another Wow. The doors were pretty sketchy looking. Lots of scratches, blemishes, and I have no idea what they were, but these circular bumps about 1/64" high by 1/32" in diameter. I mean probably 30 or 40 on each door. They sucked trying to get them sanded out, but ultimately they were eradicated. We followed the same process as was used on the front end. 2000 grit, 3000 grit, 5000 grit, rubbing compound, swirl remover, ultrafine finishing polish and Wolfgang paint sealant. The doors were worse than the front end since you had to deal with the full length body side molding, the door handle and lock, and the belt line molding. Too bad I hadn't grown my wet sanding balls while the handles and lock were off.
I am glad that is done. Well worth it, but not much fun. Here's some pictures.
  #564
Old 05-10-2014, 07:54 PM
njsteve's Avatar
njsteve njsteve is offline
Awesome. Can I have it back now?
I sent you a PM on the molding and clips.
  #565
Old 05-10-2014, 08:08 PM
Norwood's Avatar
Norwood Norwood is offline
That lift sure is nice for buffing the lower half.......
  #566
Old 05-10-2014, 10:09 PM
I might let you have it back when I am done playing with it....
The lift is nice for a lot of things, but I can't imagine not having it to do the sanding and buffing.
Ok, the last thing that got buttoned up today was the installation of new rocker panel molding. The new ones are NOS pieces that cost more than they should have. They were much rougher than I had hoped given their NOS status, but after some sanding and polishing they look really nice. A huge improvement over the battle scarred molding they replaced. I would love to see some the new repop rocker molding for comparison. I doubt the price difference for the NOS was worth it, but maybe...Have I mentioned that I am looking for body side molding?
Here's the pictures.
  #567
Old 05-10-2014, 10:16 PM
PB's Avatar
PB PB is offline
Dang Bob....are you for hire?! Love it...nice work to you and MPD!
Pat Brown
  #568
Old 05-10-2014, 11:27 PM
70RAlll 70RAlll is offline
Bob.. that Jack sure looks good.Love the gold cadmium plating vs the zinc many use. Got some pictures around here of a 18k RAIV survivor's jack that looks almost identical in color/sheen. sweet work you are doing Bob, car is really looking good..
  #569
Old 05-11-2014, 09:05 AM
The Boss's Avatar
The Boss The Boss is offline
And go racin' in the street.
  #570
Old 05-11-2014, 09:26 AM
njsteve's Avatar
Bob,
How did you sand/polish the rocker moldings? Aren't they anodized aluminum?
  #571
Old 05-11-2014, 10:45 AM
I only sanded very specific areas that had nasty scratches to limit the removal of the anodizing. Limited removal was better than leaving the gouges. I worked up from 800 grit. After that I used auto polish from course to ultrafine, metal polish, and last a coat of carnauba wax.
I almost forgot to add that i had to scrub them down with Brake kleen first to get all the GM plastic wrap residue off. That probably took longer than anything else.
  #572
Old 05-11-2014, 11:40 AM
njsteve's Avatar
I have a similar set that I bought years ago that has that same semi-permanently attached GM plastic tape junk on them.
  #573
Old 05-11-2014, 03:44 PM
165th's Avatar
165th 165th is offline
Black on an early second gen looks awesome. You've really got her looking sweet. Congratulations on the great fluff job.
  #574
Old 05-12-2014, 08:28 AM
Judge273's Avatar
Judge273 Judge273 is offline
TA radials still? Where's the F60s? Haha
Mike/Illinois
  #575
Old 05-12-2014, 09:26 AM
Like I said - There's one in every crowd...hah.
Right now I am just trying to restrict the mission creep to those things that really need some attention. However, I would be lying if I didn't admit that it hurt a little shoving that BFG into the trunk. Maybe I can spring for a set before August....
  #576
Old 05-12-2014, 07:34 PM
njsteve's Avatar
Those F60s Polyglas tires are only good for display. They do look really nice but they ride like crap.
  #577
Old 05-12-2014, 07:43 PM
Judge273's Avatar
Really? I drove on mine for over ten hours with no problems to Dayton. Roads suck worse than tire ride mostly...
Mike/Illinois
  #578
Old 05-12-2014, 08:23 PM
njsteve's Avatar
I guess once you are used to how nice they ride on modern radials, you really notice the difference when you switch back to NeanderTires.
  #579
Old 05-12-2014, 08:28 PM
I'd be happy to drive the Black Car period if I could just get my dam_ radio back from California....Maybe I can put it on a trailer and have MPD tow me around.
  #580
Old 05-17-2014, 08:04 AM
More wet sanding....
Last night I decided to tackle the worst panel on the Black Car - the trunk lid. Although the scratching was not so bad, the trunk had the worst damage from acid rain, looking almost leopard like in terms of the number of spots. It was entirely covered. I followed the same process that has been used on the rest of the car, but due to the depth of the acid rain etching I had to sand it twice with the 2000 grit paper. The results are amazing. All of the spots are gone. Completely gone. The bad news is that now you see more prominently the 3 or 4 small paint chips and imperfections that cannot be sanded out. I'll take that trade. Only the roof and rear quarters remain to be polished.
Here are the before and after pictures.
