Old 05-28-2014, 09:41 PM
transam1972 transam1972 is offline
Default MORE UNDERNEATH
I wonder how much overspray is under the trunk..I pulled it in 1990 to replace hoses..no build sheet...
ID:	365239   Click image for larger version
ID:	365240   Click image for larger version
ID:	365241   Click image for larger version
ID:	365242   Click image for larger version
Old 05-29-2014, 01:38 AM
Default REAR WHEEL DETAIL
so it is anyones guess as to what kind of shape the rear brake hardware is considered to be in after 43 years...I see the parts have the original paint (58k miles)..also I tried to remove some silver overspray that took off the Lucerne blue...most likely after the car is painted I would touch up the sound deadner in a few spots and most likely painting over the original wheel well sound deadner to preserve the original texture in the wells...and just hit theframe with a bit of deadner overspray to dress it up...these are the problems you run into when restoring a car and trying to preserve originality..thats why low mileage true original survivior cars are better than a restored car...only original once
ID:	365250   Click image for larger version
ID:	365249   Click image for larger version
ID:	365251   Click image for larger version
ID:	365252   Click image for larger version
Old 05-29-2014, 07:51 AM
165th's Avatar
165th 165th is offline
Hi Glenn, the rear end ID is on the passenger side facing towards the front of the car.
CMG is 4spd. GYG is automatic.
The next 3 numbers are the Julian date code
The next number is the shift
I think the last letter indicated the manufacturing plant which I think G Chevy Gear.
Good luck finding it. Show a picture of it when you find it.
Old 05-29-2014, 01:37 PM
Default AXLE #S
THANKS!! 165TH!!...for better or worse this is what I found..so I dying to know what this means..this is cool stuff to find out after 29 years!!..I was always in the wrong locations...so I need you to tell me good or bad whats up?!..looks like PX G60191
ID:	365286   Click image for larger version
ID:	365287   Click image for larger version
ID:	365288   Click image for larger version
ID:	365289   Click image for larger version
Old 05-29-2014, 03:22 PM
Default REAR UNDERCARRIAGE
one photo shows a stamp found on the drivers rear brake drum, another is the factory installed twisted rear seat belt,,the rest are just of the under carriage with the gas tank removed...I call this the poor mans garage as its quite obvious (and dangerous when I am here)..no lift..etc...I was not expecting a full tank of gas (I don't smoke either)..and luckily I did not break my rear window.no damage to the tank either...note to self..get rear window installed ASAP...some of these hoses are original as they have silver overspray..so I know a few of these clamps are original..the passenger outer wheelhouse was replaced..I plan on prepping the inner wheelhouses. seam seal. then undercoat...and leave everything else untouched
Name:	brake stamp.jpg
ID:	365300   Click image for larger version
Name:	factory installed seatbelt incorrect.jpg
ID:	365301   Click image for larger version
ID:	365302   Click image for larger version
ID:	365303   Click image for larger version
Old 05-29-2014, 03:30 PM
Default UNDER CARRAIGE
random underneath..
ID:	365305   Click image for larger version
ID:	365306   Click image for larger version
ID:	365307   Click image for larger version
ID:	365308   Click image for larger version
Old 05-29-2014, 03:36 PM
Default REAR UNDERCARAIGE
the classic MQ line I used..hey get some foam on this thing(his 1973 Brewster green T/A)...IM up to my butt in gas!!!....
ID:	365310   Click image for larger version
ID:	365311   Click image for larger version
ID:	365312   Click image for larger version
ID:	365313   Click image for larger version
