#461
Old 05-28-2014, 09:36 PM
transam1972 transam1972 is offline
Default UNDERNEATH
is that the original exhaust system & muffler??
ID:	365234   Click image for larger version
ID:	365235   Click image for larger version
ID:	365236   Click image for larger version
ID:	365237   Click image for larger version
  #462
Old 05-28-2014, 09:41 PM
Default MORE UNDERNEATH
I wonder how much overspray is under the trunk..I pulled it in 1990 to replace hoses..no build sheet...
ID:	365239   Click image for larger version
ID:	365240   Click image for larger version
ID:	365241   Click image for larger version
ID:	365242   Click image for larger version
  #463
Old 05-29-2014, 01:38 AM
Default REAR WHEEL DETAIL
so it is anyones guess as to what kind of shape the rear brake hardware is considered to be in after 43 years...I see the parts have the original paint (58k miles)..also I tried to remove some silver overspray that took off the Lucerne blue...most likely after the car is painted I would touch up the sound deadner in a few spots and most likely painting over the original wheel well sound deadner to preserve the original texture in the wells...and just hit theframe with a bit of deadner overspray to dress it up...these are the problems you run into when restoring a car and trying to preserve originality..thats why low mileage true original survivior cars are better than a restored car...only original once
ID:	365249   Click image for larger version
ID:	365250   Click image for larger version
ID:	365251   Click image for larger version
ID:	365252   Click image for larger version
  #464
Old 05-29-2014, 07:51 AM
165th's Avatar
165th 165th is offline
Hi Glenn, the rear end ID is on the passenger side facing towards the front of the car.
CMG is 4spd. GYG is automatic.
The next 3 numbers are the Julian date code
The next number is the shift
I think the last letter indicated the manufacturing plant which I think G Chevy Gear.
Good luck finding it. Show a picture of it when you find it.
  #465
Old 05-29-2014, 01:37 PM
Default AXLE #S
THANKS!! 165TH!!...for better or worse this is what I found..so I dying to know what this means..this is cool stuff to find out after 29 years!!..I was always in the wrong locations...so I need you to tell me good or bad whats up?!..looks like PX G60191
ID:	365286   Click image for larger version
ID:	365287   Click image for larger version
ID:	365288   Click image for larger version
ID:	365289   Click image for larger version
  #466
Old 05-29-2014, 03:22 PM
Default REAR UNDERCARRIAGE
one photo shows a stamp found on the drivers rear brake drum, another is the factory installed twisted rear seat belt,,the rest are just of the under carriage with the gas tank removed...I call this the poor mans garage as its quite obvious (and dangerous when I am here)..no lift..etc...I was not expecting a full tank of gas (I don't smoke either)..and luckily I did not break my rear window.no damage to the tank either...note to self..get rear window installed ASAP...some of these hoses are original as they have silver overspray..so I know a few of these clamps are original..the passenger outer wheelhouse was replaced..I plan on prepping the inner wheelhouses. seam seal. then undercoat...and leave everything else untouched
Name:	brake stamp.jpg
ID:	365300   Click image for larger version
Name:	factory installed seatbelt incorrect.jpg
ID:	365301   Click image for larger version
ID:	365302   Click image for larger version
ID:	365303   Click image for larger version
  #467
Old 05-29-2014, 03:30 PM
Default UNDER CARRAIGE
random underneath..
ID:	365305   Click image for larger version
ID:	365306   Click image for larger version
ID:	365307   Click image for larger version
ID:	365308   Click image for larger version
  #468
Old 05-29-2014, 03:36 PM
Default REAR UNDERCARAIGE
the classic MQ line I used..hey get some foam on this thing(his 1973 Brewster green T/A)...IM up to my butt in gas!!!....
ID:	365310   Click image for larger version
ID:	365311   Click image for larger version
ID:	365312   Click image for larger version
ID:	365313   Click image for larger version
  #469
Old 05-29-2014, 03:39 PM
Default UNDERCARRAIGE REAR
RANDOM..the first photo shows how the passanger side inner tail bracket deteriorated (thankfully, that was all there is..although the original drop offs were shot..this is the area that gets hit hard with rust, as we all know).. on that side..the rest is intact..both frame rails are solid..as I have said some sort of rear bumper damaged occurred and I opted to just massage it.... instead of cutting out metal. even if I had the new parts I would not have pulled the rear apart for it is a major task as I am certain some know from experience!!!.the drop off and 1/4 panel replacement restored the integrity...I plan to focus on this project this weekend correct primer colour on the drop offs & some undercoating ..so look for results!!
ID:	365316   Click image for larger version
ID:	365317   Click image for larger version
ID:	365319   Click image for larger version
ID:	365320   Click image for larger version
  #470
Old 05-29-2014, 03:55 PM
Default UNDERNEATH
I am certain you can see the metal distortion from underneath on the trunk pan..I used filler & sound deadner on top...since no rusted trunk pan, in 1990 I opted for this type of repair as a lot of funkiness on these F bodies when they all come together in this rear and trunk area...I suppose a major rear end hit and it all over...
ID:	365322   Click image for larger version
ID:	365323   Click image for larger version
ID:	365324   Click image for larger version
ID:	365325   Click image for larger version
  #471
Old 05-29-2014, 03:57 PM
Pepi's Avatar
Pepi Pepi is offline
Yes, get that rear glass some place safe like installed
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #472
Old 05-29-2014, 04:01 PM
Default UNDERNEATH
I did need to get the over 10 year old gas out of the tank...also 2 different type of nuts on the gas tank straps?....
ID:	365327   Click image for larger version
ID:	365328   Click image for larger version
  #473
Old 05-29-2014, 04:04 PM
Default REAR GLASS
I know!!..like where it belongs!!..I am meaning to stop into an autoglass place and bring it in to see if they can repair the wire to the glass..then come out and install...I have the screw in stud mounting clips coming in..so its a top priority!!!
  #474
Old 05-29-2014, 04:34 PM
Held for Ransom's Avatar
PX - 3.23:1, Posi-Traction. Probably from a '76 Firebird Trans Am.
Is there a conversion U-joint? Different driveshaft?
  #475
Old 05-29-2014, 04:56 PM
Default REAR AXLE
now its getting weird...I will take photos of the drive shaft connection..could this have been a new replacement assembly??..what about gear ratios??..when I get the muffler out of my way..I will be able to pull the cover if need be..pix coming..thanks!..a 72 455 H.O. with auto/a/c was that 3:08??
  #476
Old 05-29-2014, 05:35 PM
Default DRIVESHAFT & REAR AXLE
the suspense is killing me...
ID:	365333   Click image for larger version
ID:	365334   Click image for larger version
ID:	365335   Click image for larger version
ID:	365336   Click image for larger version
  #477
Old 05-29-2014, 07:39 PM
I can't tell by the pictures. You have to measure the length and size of each shaft/cap. Someone may have just used a junkyard housing and transferred everything else. They also could have used the '76 driveshaft and have the conversion U-joint on the transmission yoke side.
  #478
Old 05-29-2014, 07:52 PM
Default DRIVESHAFT
unfortunately I am not familiar enough of what we are discussing...work would have to be done before 1985...why might a rear axle need to be replaced?..also when I get the muffler out of the way..should I pop the cover to see whats inside?...I would like to..is there a drain?..any info regarding this is appreciated...thank you
  #479
Old 05-29-2014, 08:11 PM
No drain. Loosen the bolts and pry cover away from housing with a catch pan underneath. Axle bearings may have been making noise, chipping a gear tooth or more or breaking the pinion flange are some reasons to pick up lower mileage rear from newer vehicle in a salvage/junkyard. Or, maybe it was purchased from a dealership (but would have easier to rebuild). Maybe a side accident bent the assembly.
  #480
Old 05-29-2014, 08:41 PM
Default THANKS FOR THE INPUT!!
the cars owners worked at the dealership...I will pop the cover to see whats up..was not expecting this surprise but I have handled it well!!!..I will post some driveshaft connection pics..and thanks again!!
ID:	365360   Click image for larger version
ID:	365361   Click image for larger version
ID:	365362   Click image for larger version
