Old 06-24-2014, 06:23 PM
David Holmberg's Avatar
Originally Posted by 63gpman View Post
Do you need to run a little higher compression on the Aluminum heads to get full use of them?
You can use 1pt of compression more with aluminum heads, and with the new CNC chamber you can probably get away with even more. (Depending on your cam/converter/gear choices.)
