#81
Old 08-08-2012, 08:22 AM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
Originally Posted by lemans411 View Post
can this mod be done to e heads ? mine are soft here from lifting heads under boost. and where do i send em?
Yes, this mod can be done to any cylinder head, give me a call to discuss.
Calvin Hill
Hill Performance
708-250-7420
  #82
Old 10-17-2012, 09:39 PM
Default Update 10-17-12
Track results have shown a major improvement in head gasket life with the Tiger special alloy insert. In one case, the racer was getting minimal head gasket life, less than 15 passes under NOS use. The racer had 12 passes after the insert was installed, pulled the head after needing to reseat a valve, the head gasket looked great and reused the gasket, 20+ additional runs and the gasket still looks great. That's twice the head gasket life and can be reused.
Glenn Sedig ran all season on the same head gaskets with well over 50+ runs and the leak down is better between the center exhaust ports versus the outside cylinders.
All other users have no reports of head gasket failure to date.
We will be incorporating this modification in other Pontiac cylinder heads starting with the Edelbrock Performer as of next week.
Calvin Hill
Hill Performance
708-250-7420
  #83
Old 06-04-2013, 07:25 AM
rompn63's Avatar
rompn63 rompn63 is offline
Thanks to Glenn and Calvin,
I have 36 runs since Glenn did the insert in my Tigers. I just did a leak down and the results show no difference in leak down between the center cylinders and the end ones.
16-1 compression, 3620 lbs, 5 speed.
I"m a happy camper.
  #84
Old 06-05-2013, 12:31 PM
Region Warrior's Avatar
Sounds like the price is worth it vs tear downs and repairs.
  #85
Old 06-23-2014, 09:28 PM
J.C.you's Avatar
J.C.you J.C.you is offline
btt, any long term results on the mod?
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #86
Old 06-24-2014, 04:50 PM
rompn63's Avatar
I pulled my Tigers at the end of October with over 60 passes with the insert.
The area between the center cylinders looked better than the end cylinders.
Money well spent.
Thank's to Calvin and Glenn.
  #87
Old 06-24-2014, 09:40 PM
60man's Avatar
60man 60man is offline
Money well spent.
Great Joe.... I feel much better now..
Hope to catch up to you in Norwalk...
ECM member.
2008 Outlaw Pontiac Drag Series Champion
MANDRA
Do it now fool! Life is short.
69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'.
Going back to track with pump gas engine....
My 60 Ventura retired to street/strip duty..
  #88
Old 06-27-2014, 10:14 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Money well spent.
Good Deal!
Why only 60 passes? I call 60 passes the month of April and the 1st part of May.
Are the Tiger heads a once in a while race head?
Does anyone use them and double enter often?
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 1/8 [email protected] 1/4 [email protected] in St.Louis April 2026
  #89
Old 06-27-2014, 11:14 PM
60man's Avatar
Originally Posted by S/st 54 View Post
Good Deal!
Think what Joe was saying is "all is good"...
My gaskets would start to go away about 60 passes at 15 - 1 CR.....
With inset his center holes are better than the end holes..
I had my heads done and hope for same results
Double enter often..??
ECM member.
MANDRA
  #90
Old 06-28-2014, 12:18 AM
S/st 54's Avatar
Ok I wish Joe all the luck in the world. I also hope you Troy Have the most fun at the track you can!
Double enter is a bracket racing term: entering in Super Pro and Pro.....Or like I do often enter a local bracket race in S/ST and Super Pro.......I'm literally running my butt off from the second I drop the back Door and un strap the car till hopefully the final!
  #91
Old 06-28-2014, 11:21 AM
60man's Avatar
Thanks man....Be nice to get back out. Getting a late start but chit happens..
Be great running season without replacing head gaskets too..
I might double dip now...
Good luck..
ECM member.
MANDRA
  #92
Old 06-28-2014, 01:06 PM
S/st 54's Avatar
Good luck..
Just remember Troy your not another year older,your another year BETTER this year!Good Luck!
  #93
Old 06-28-2014, 11:41 PM
60man's Avatar
Thank ya Sir...! I tend not to pay attention to age as I do to just do better than before..
Good luck to you..
ECM member.
MANDRA
  #94
Old 07-01-2014, 10:41 AM
J.C.,
Every installation of this insert has provided excellent results. We've incorporated this into other heads also with ZERO issues.
Thanks.
Calvin Hill
Hill Performance
708-250-7420
  #95
Old 09-01-2015, 06:10 PM
Jim Zeek's Avatar
Jim Zeek Jim Zeek is offline
any more results? used with copper? used with cometics? thanks with
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial
http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1
  #96
Old 09-02-2015, 07:19 AM
badgto's Avatar
badgto badgto is offline
I had Calvin put the insert in my cv-1 heads several years ago when I kept burning head gaskets and burn a gap between 4 and 6 chambers. I use cometic head gaskets. Went to mannual fuel injection fix problem and insert works great.
  #97
Old 09-02-2015, 01:45 PM
Glenn Sedig Glenn Sedig is offline
Default inserts
We have many sets of heads out with the inserts. Tiger's CV1's Edel's Winsler's. To my knowledge none have had a problem. On my engine with close to 15:1 compression I have had no problems. When tearing down, the area of the gasket where the insert is, shows witness marks of the insert on the gasket. The gasket shows no sign of heat or leakage. The insert is pulling the heat away from the area so that the alum web in the head does not get hot enough to deform, witch reduces clamp pressure. Low clamp pressure reduces the inserts ability to remove heat thus allowing the gasket and head to burn through.
  #98
Old 09-10-2015, 11:36 AM
potentpontiac's Avatar
potentpontiac potentpontiac is offline
Glenn. Did you pick up 4 hundreds in 60ft just by going to a bigger starting line chip? Congrats on the WIN!!! My converter is way too tight. I was going to start at 4600 and go from there.
  #99
Old 09-17-2015, 07:14 PM
Jim Zeek's Avatar
Calvin. Sent you a pm
  #100
Old 09-17-2015, 07:20 PM
Got it.
Thanks.
Calvin Hill
Hill Performance
708-250-7420
