Old 06-30-2014, 04:14 PM
Alvin's Avatar
Alvin Alvin is offline
Thumbs up
Originally Posted by Bentwheelbob View Post
I'm trying to piece together the exhaust system and want to go with a 2.5" system. I've looked at the Dynomax mufflers and like them, but need help on either side of the muffler. I was going to get the Pypes system, but unless you get the X-Pipe system the muffler back tailpipe setup is not engineered for splitters. I don't really want to go with the X-pipe, so that would appear to rule Pypes out since the splitters are a must.
I'm certainly no expert, and many here can provide you more detailed info of current sources. Below are MOs. Hope it helps by giving you some ideas.
Questions:
1)If I can purchase from the Mufflers through the spiltters prebent from an online supplier, couldn't a local exhaust shop just bend the pipes from the manifolds to the muffler inlet.
Yes, since they won't be as original anyway - YPipe to CatCon - on 1978's. OR, you could source earlier 2nd Gen pipes for a 1974 manifolds to mufflers.
2) Any recommendation on suppliers for the over axle pipes running from the muffler outlet to the splitters?
Have you called PY and ask them with respect telling them you do not want an X-Pipe?
Check local GM dealer parts sources?
Gardner Exhaust?
Local exhaust shops...
I have old Year One Catalogs from the 90's that listed the OEM tailpipes & splitters...was same time they still sold factory sheet metal, etc.
Make sure you get them - tailpipes - with the tabs on the tailpipes that slide into the rubber lined hangers.
3) Same on splitters. Whose got the best pieces?
Splitters have been around for a long time from various sources, check the gauge of metal and the chrome plating.
I appreciate any help.
Thanks,
Bob
PS: sorry for the PM inbox full, I keep it that way got tired of PITA PMs from Dillion...
Old 06-30-2014, 05:49 PM
Bentwheelbob's Avatar
I'm traveling again this week and want to get the exhaust ordered, but don't have the benefit of being home to check some details. Are the standard log manifolds on the W72 a two or three bolt flange?
Old 06-30-2014, 07:32 PM
Alvin's Avatar
1978 Pontiac Service Manual shows manifold to exhaust pipe Fig. 6F-13 Exhaust Manifold Connections F Series Typical VIN Code Z:
L.H. Side 3 studs
R.H. Side 2 studs
