More testing today... I had been through this last year, but decided to break it all down again. wheels up supported by diff, I did the following: --Normal --No wheels --No drums. --with no drums, moved the pinion angle up & down a few degrees. With all of the scenarios, I can get the pitch of the vibration to change, but it never goes away. Always comes on around 60-65, and real steady and more noticeable from 70-100. Next step I think is "Proven Force", which is our local driveline shop where the shaft was balanced last year. I may just go through the whole drive shaft with new yoke, etc, that way I can get the correct ujoint on the differential side, instead of the Pontiac-to-chevy style, and I will know what I have, instead of the PO's mess. |
I know and that was my point, he said he is moving it around installed.
![]() 1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi. Everything installed, fired up and tuning has begun! |
Yeah to me that sounds like way too much play
Quick update... Brought the driveshaft in. Showed the tech a video of me moving the driveshaft while installed. He brought out a trans shaft, and then noticed my yoke splines had a twist about 3/4 of the way back.
Sales desk just called me back to say the shaft was way out of balance, needed the new yoke (which I planned on) and two new ujoints. About $200. I suggested I had no issues with this at all, but why was it delivered to me in this condition last year from their shop after a standard balance? His comment was "no way did this shaft leave our facility in this condition". As I mentioned, my company does a great job as well 99% of the time, but there is always a case when someone having a bad day screws it up. He agreed and of course we moved forward with repairs. If what he says is true, I can only assume the previous guy spun it up and balanced as-is, similar to balancing a bad tire mounted on a bent wheel. you can balance it, but the end result is still messed up. (only guessing here) As mentioned earlier in this thread, I have always had the vibration, even after the last balance. BUT, I will be very happy if this takes care of the problem!! Wish me luck! Last edited by leeklm; 07-07-2014 at 06:05 PM. |
Good Luck!
I hope you got it all worked out.
Awesome Lee!!, Sounds like u found it!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
just listining in
color me gone |
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry! - Mike 1967 GTO |
... and 3 amen's! Put the newly fixed drive shaft in and could immediately feel a difference in how tight the yoke fit in the trans. Spun it up on jack stands and while not as smooth as a modern car, much better (did have my drag slicks on, with not so perfect rims).
Took a test drive and wow, what a difference! Nice smooth ride, even at slower speeds where I did not think I was feeling the vibration. I wonder, as it relates to my recent chassis dyno results, would a driveshaft this out of whack impact my HP numbers to any noticeable difference? It is frustrating that the first guy to balance the drive shaft last year gave me a POS. I have spent hours tracking this issue down but on the bright side, I am sure I learned a few things along the way. I am just happy that it is fixed!! Thank you everyone for the feedback and advice! Last edited by leeklm; 07-08-2014 at 10:27 PM. |
Now im thinking I need a new drive shaft.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
Grats! I knew that sounded like too much movement, glad it worked out for you! You going to have the car at Car Craft?
Crossed my mind, but that event always looked like a pita to have your car at... Have you done it? I do hope to get out to Rock Falls this wknd for a couple of runs.
Yeah I plan on bringing my GTO. As long as your car can handle idling through the fair for an extended amount of time in potentially hot conditions to find a place to park you should be fine. There's a lot of nice cars to see, its fun to bring a car in....pack a cooler make a day out of it.
![]() 69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
Got up to about 80 and yes, noticed a BIG change for the better.
