Old 08-16-2014, 11:31 AM
cnhorn63 cnhorn63 is offline
Default Harmonic Balancer Slipped?
My motor is a '72 455 and has been running hotter than normal. I adjusted the timing to factory specs. Timing does not seem to be set correctly, advanced too far. I rotated the engine and located TDC with the #1 cylinder. The HEI rotor is pointing to the #1 cylinder. I assume that the notch on the harmonic balancer should be lined up with 0 on timing the cover. It is not even close to 0. Looks to be at least 6 degrees above where the timing marks begin on the cover. Just want to confirm that the Harmonic balancer rubber ring has slipped?
Old 08-16-2014, 12:07 PM
Blued and Painted's Avatar
Blued and Painted Blued and Painted is offline
So your using some sort of probe in the spark plug hole to confirm TDC.
I like the replacement balancer's with the timing marks etched around the outer ring.
Makes it easier to watch your timing curve and valve adjustment is a snap.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk
Old 08-16-2014, 12:21 PM
STEELCITYFIREBIRD's Avatar
Make sure mechanical advance is not stuck in dizzy.
https://www.youtube.com/watch?v=RENhHI9n65I
Old 01-30-2019, 10:24 PM
I'm confused. What does the crankshaft gear have to do with the balancer/timing mark?
Bill Nye.
Old 08-16-2014, 01:19 PM
Setting your rotor to Number one just gets you in the ballpark. You will need to turn engine to #1 TDC with a small rod/dowel into the #1 Cyl and feel the piston come up until it stops and then go down, then turn it back until you feel it go back up, you will be able to find a happy medium , that will be TDC, maybe not exact, but close enough. Then look at your timing mark, if its not "zero" then the balancer has slipped, now make your own mark and thats your new TDC mark. At least you will be able to set your timing while you are waiting to replace your balancer. Most people would never know there balancer had slipped until they went adjusting the timing. When they check it "wow, thats way off" then they set it where they usually do, and it runs worse. Big red flag.
Old 08-16-2014, 01:53 PM
Thanks for the quick replies. Yes, I used a straw as a probe to locate TDC in the #1 cylinder. I'm confident that I am in the ball park for TDC. The rotor pointing to the # 1 cylinder was not exact but close. Recommendations for a replacement harmonic balancer.
Old 01-31-2019, 11:18 AM
OK! Now I see, all good.
Bill Nye.
Old 08-16-2014, 01:59 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Pioneer and BHJ make good balancers, as well as others. I would stay away from Professional Products balancers though, as I have seen a lot of issues with them.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 08-16-2014, 03:43 PM
t money t money is offline
I think it overkill in need and price without nosing anything about your comb but I have a SFI balancer in the for sale part of this forum if you what to look.
Old 08-16-2014, 06:18 PM
To check and/or make a new mark on the balancer, if you want it to be exact (and it really needs to be)
On an assembled engine you'll need a piston stop that screws into your spark plug hole. Very simple and cheap tool everyone should have in their toolbox.
Insert piston stop. Rotate engine clockwise until #1 piston touches, mark the balancer in this position, for example it may read 20 degrees BTDC.
Now rotate the engine counterclockwise until #1 piston hits the piston stop. Mark this position on your balancer, for example this time it may read 15 degrees ATDC.
What is exactly in the middle of those 2 marks is your new SPOT ON top dead center, which would be 5 degrees BTDC with the example I've given, which would show your balancer was off by 5 degrees.
I do this with every engine, usually during assembly while I am degreeing the camshaft,,,,,as I've had brand new balancers that weren't marked correctly or possibly the keyways are off slightly etc...You just never know with some of this aftermarket stuff. ALWAYS CHECK, cheap insurance and it only takes 5 minutes.
Old 08-16-2014, 07:56 PM
ASSUME will always get you into a lot of trouble.
KNOW lets you sleep well at night time and feel good when you put your foot into it.
ps If you verify that the balancer slipped toss it, it will continue to move from the time it first moved.
Old 08-16-2014, 10:08 PM
Thanks formulajones and Tom, I plan on obtaining a piston stop to accurately determine TDC. Not a lot of info known about this engine, its an older build and prior owner did not know much either. Prior owner had the vehicle in storage 10+ years so very possible the rubber ring is done. Thanks for every ones input.
Old 01-29-2019, 01:03 PM
Colin70TA Colin70TA is offline
I just finished degreeing my OLD faithful cam (which I had to advance 4 degrees to get at a 107.5 ICL). Confirmed top dead with a dial indicator. Went to install the timing cover and balancer and the TDC timing mark on my Pioneer balancer is lining up at 4 degrees before. Does this make sense? Should I just mark the balance to make a new reference to zero?
I am positive I did TDC right, took measurements on 0.200 on either side of TDC and recorded on degree wheel and found top dead that way.
1970 Trans Am, numbers matching, White, Auto, A/C, Owned since I was 15.
1973 Trans Am, numbers matching, Brewster Green, Saddle interior...Sold :-(
1978 Trans Am 400-4spd, non-numbers matching 400, Low compression daily driver, [email protected] 1/8 mile....Sold :-(
Old 01-29-2019, 04:19 PM
Dial indicator on piston, correct? Not thru timing chain.
If so remark zero, put a paint stripe or centerpunch on balancer hub to ring.... to indicate if ring ever shifts in future.
Old 01-29-2019, 08:18 PM
Dial indicator was on the piston
Sent from my SM-A530W using Tapatalk
Old 01-29-2019, 07:57 PM
darbikrash darbikrash is offline
Just did this degreeing in my stroker 400 using an OF 2 cam ground on a 112 LSA. I used a dial indicator as well, and found it about 4 degrees off. I messed with it for hours, and switched to a hard stop on the top of the cylinder bore to set TDC instead of the dial indicator.
Results within 1/2 degree. Put the balancer on and it was also within 1/2 degree.
The hard stop (metal strap across the cylinder bore with a bolt in the center as a stop) method is more accurate than using dial indicator, this is because at or near TDC the crank can rotate a few degrees with the piston not moving much due to dwell.
Try it with a hard stop and see if things change.
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
Thanks, I was thinking that might be the case too because of dwell, which was why I didn't actually mark my measurements when the piston was 100% up but rather equal amounts on both sides of TDC. This gave me 2 readings on the degree wheel which I used to find true TDC. Now I am wondering if that's the correct way?
If that was correct then I'll just caulk up the balancer to machining or whatever and mark my new TDC on it.
Old 01-29-2019, 01:08 PM
Too much advance will absolutely not make the motor run hot, but a retarded setting of the timing due to the Balancer slipping , or a timing chain that it streched sure will !!
Old 01-29-2019, 05:33 PM
Lee's Avatar
Lee Lee is offline
When you install the new damper, make a mark on the pulley to match up with the TDC groove on the outer ring. Then if the ring slips again, it will be obvious.
I saw a Summit Racing SFI damper for a SBC not too long ago, and it had slipped about 40 degrees.
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 01-29-2019, 08:23 PM
Lee's Avatar
Lee Lee is offline
You need the dial indicator right above the wrist pin. If you are at the top or bottom of the piston you will get errors as the piston rocks.
