Old 09-10-2014, 04:11 PM
GP65AT's Avatar
GP65AT GP65AT is offline
Thanks,
yes it is a Carter AFB, I have fogotten to write this.
But I would like to know which exact type it is to buy the right spare parts.
The only number that would fit would be 6-1694 , but I can not really find right fitting spare parts?
So see attached pictures, maybe they will help.
Stefan
Name:	P1050797 (Medium).jpg
ID:	375739   Click image for larger version
Name:	P1050799 (Medium).jpg
ID:	375740   Click image for larger version
Name:	P1050801 (Medium).jpg
ID:	375741   Click image for larger version
Name:	P1050803 (Medium).jpg
Old 09-10-2014, 04:26 PM
scld1354's Avatar
scld1354 scld1354 is offline
From http://www.thecarburetorshop.com/Carburetor_ID.htm. The owner of that shop is a member here (carbking).
"AFB Series – (4 barrel) (1957 – 2001) metal tag: also some units stamped on edge of flange, some units stamped center of bowl in rear, some units stamped along bowl – airhorn seam in front, some units NOT stamped (tag only)"
Depending on the year of your can, and if it's the original carb, you can use this LIST from the same webiste to get an idea of what carb your car has.
For example, for a 1965 car with a 389, auto trans, and a 4bbl, if you look about half-way down the page, you'll see it came with a Carter AFB #3896. The rebuild kit from that site would be the last column (#548)
Originally Posted by lust4speed View Post
Welcome to the broken nipple club - I'm a charter member.
Old 09-10-2014, 05:26 PM
Deadhead's Avatar
Deadhead Deadhead is offline
Tons of kits for these on E-Bay. Very easy to do. Pretty much all Carter 4bbls from '63-66+ take the same kit. Do a search for your year pontiac and carb kit, and you should find what you need. If I remember right, there are not many or any helpful #s on the carb if it has no tag on it.
"If you do everything you'll win"
-LBJ
13 Smiles per Gallon:
66 Bonneville wagon
66 Bonneville 2d HT - In perpetual progress
2005 GMC L-33
