Old 09-25-2014, 11:07 PM
Poncho_Villa's Avatar
Poncho_Villa Poncho_Villa is offline
Originally Posted by JohnFromVentura View Post
Looks great. Where did you find the retractable seat belts?
They were in the car when I bought it. I'm pretty sure they were installed at the dealership when purchased new.
Old 10-06-2014, 06:59 PM
heater63's Avatar
heater63 heater63 is offline
Default a work in progress, but coming around
Been working on this one on and off for the past year. In paint and going back together. there was more damage then I originally thought to both quarters but was able to straighten the passenger side and had a usable quarter to cut a patch out of from her old black car. Will post more pick once it is together and outside.
here is the original post of this car.
http://forums.maxperformanceinc.com/...t=bargain+year
"If you aren't first, your last." Ricky Bobby 2006
Old 10-18-2014, 07:04 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default Classic Exhaust kit
Working on the Lemans convertible, today. The dual exhaust kit is in place via jack stands until hangers and clamps are figured out. The kit from Classic Exhaust is 2 1/4" from the exhaust manifolds to the mufflers and 2" out of the mufflers to the tail pipes. The kit uses the stock hanger locations. The mufflers are right and left sided and can't be switched. Adjustable jack stands make the install fairly easy to mock up.
ID:	379244   Click image for larger version
ID:	379245   Click image for larger version
ID:	379246   Click image for larger version
Old 10-18-2014, 07:27 PM
Radman's Avatar
Radman Radman is offline
Try getting a curved pipe that will go over the swing axle in the rear. If not you will probably drag the exhaust at speed bumps and some driveways.
Old 10-18-2014, 08:19 PM
c5farmer's Avatar
Default tail pipes
Thanks Radman. I will try to tuck the tail pipes up as close as possible. Anyone else with the under-axle tail pipes? What is your experience?
