Old 10-02-2014, 07:51 AM
Cliff R's Avatar
Cliff R Cliff R is offline
"Cliff,
How much stall on the converter?"
I have the old reliable "Jim Hand" 10" unit. Mine flashes to right to 3400-3500rpm's on a hard run with traction. This is just a tad higher than most folks see, but every converter I've had in this car, even the 13" unit flashed pretty high. Might be because of how hard my engines "hit" the converter, the tune on them is pretty decent, and they are built to make a TON of low end power, with super-quick throttle response right off idle, etc.
It's amazing how well these Continental converters are "locked-up" on top end. I go thru just past 5000rpms at over 120mph, which on the calculator shows very little slippage at all.
Most converters of this type will show 400-600rpms slippage on top end, some even more. Mine is less than 150rpm slippage when I do the math on it.......Cliff
Old 10-02-2014, 03:01 PM
ta man ta man is offline
This is a shot from a 1.7119 60 ft..the other two were 1.66's...only three way adjustable shocks nothing else.Not a bad launch for 3.08's...
Old 10-02-2014, 08:07 PM
mchell's Avatar
mchell mchell is offline
good looking car.....
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 10-03-2014, 05:16 AM
Be nicer if it was washed and detailed was up until 3am the night before..after tuning the father inlaws car,working on the son's car meanwhile finishing up a built in bookcase in the kitchen..finally got around to my car...
Old 11-28-2014, 02:36 AM
67ramair4's Avatar
67ramair4 67ramair4 is offline
Question New Best still with 3.08 gears
Consider me "old fashioned", but the brain still has a hard time understanding these ET's and MPH with the rear gear ratio advertised! What horsepower would you have to have with 3.08's and the ET's listed??
Old 11-28-2014, 05:16 AM
Torque is really what does the job!Its really the head cam package by SD performance..that gets the credit..I've done a few tweaks but could still have a better setup,my heads are still 85 cc's,non ported torker 2 intake,machine shop 462 with cast rods and heavy TRW pistons!I'm also still not satisfied with the carb tune and settled on the ignition curve.
