Old 10-05-2014, 10:14 AM
67'7F6'Bird's Avatar
We pulled the motor, Pulled a few rod caps and small pieces of Copper were embedded into them. Pulled the Camshaft and large grooves were dug into all of the Cam Bearings.
Thrust checked in at 11 thousandths.
Top End disassembled and brought everything to the Machine Shop, R&L in Dover, NH.
I am having Leo go through the Heads - Disassemble, Clean and Reassemble.
He went through them in 2010.
The Block will get Honed and all new Coated Bearings installed & Polish Crank. And anything else Leo comes across will get fixed.
The Oil Pump check Ball was not stuck open.
Steve
ID:	378012   Click image for larger version
ID:	378013   Click image for larger version
Name:	2014-10-03 23.11.49.jpg
ID:	378014   Click image for larger version
Name:	2014-10-03 23.11.21.jpg
Old 10-07-2014, 08:06 AM
AG's Avatar
AG AG is online now
What did the main bearings look like? Check the thrust surface of the crank.
Old 10-10-2014, 06:43 AM
AG's Avatar
AG AG is online now
What are those pushrods?
Old 10-10-2014, 08:23 AM
Hi Tony,
I didn't pull the Main caps, I asked the machine shop to see if he could determine what caused the damage.
We did notice my torque converter had the head of the flexplate bolts riding on it, as the paint was gone with slight impression on the torque converter, the flexplate bolt heads showed slight wear too. This was shimmed properly with washers when first installed and there was about an 1/8 inch gap. The converter has anti-ballooning plates.
The push-rods are comp cams - welded ends.
Steve
