#4421
Old 10-08-2014, 11:43 AM
frank.g frank.g is offline
All SD's built for production (the ones with an "X" in their VIN) were after the emission change over date, so all have the later emission system. Some intake manifolds were originally manufactured for the earlier system, and they were re-tapped and stamped with the later part number. Occasionally, you can see the double stamp on some of these manifolds.
  #4422
Old 10-08-2014, 11:53 AM
Alvin's Avatar
Alvin Alvin is offline
Wink
Cool thx. Reason for my Q here:
The next time you see a '73 Pontiac model like Steve Schappaugh's SD-455 Trans Am, check under the hood and take a close look at the emissions control system. Many fail to realize that two separate systems were used that year. Although each had the same basic components and functioned similarly, the early system fell victim to the EPA's watchful eye. Continue on as we discuss the first and second types and explore why changes occurred. Read more: http://www.highperformancepontiac.co...ntrol_systems/
  #4423
Old 10-08-2014, 12:02 PM
Interesting observation. Steve Schappaugh has had many SD's over the years, and it has been a long while since I have seen any of his, so I don't know to which car the observation is referring to. It's an open ended statement, so I can't tell from it whether Steve has a pre-production car, whether he retro fitted an early system to his car (unlikely as that would be) or whether he got the one that slipped out the door. I have learned thru the years with GM to never say "never". But, I will say, for all my years that I edited the SD Registry, none of the cars registered were built prior to the cutoff date that the emission system switch occurred.
  #4424
Old 10-08-2014, 12:46 PM
That blurb from the text under the picture was referring to the fact that the SD was different than the early engines I think?
Here is what was in the article later on:
Discussing the emissions system of the Super Duty 455, McCully stated that preproduction SD engines with the 041-spec camshaft such as those found in the engineering test mules and press cars should have had the first-type system. But EPA certification for a cam change delayed the SD's release until late April 1973. Since the changeover to the second-type system occurred prior to that, it is unlikely that any production SD engines received the first-type system.
The thread on Micheal's 'test' TA probably had the 1st version egr.
  #4425
Old 10-08-2014, 01:35 PM
After a little research... I found this.
*N41 Power steering and JL2 Power disc brakes were required options with the SD-455
  #4426
Old 10-08-2014, 05:18 PM
74 SD455 Formula 74 SD455 Formula is offline
Here's a copy of my build sheet. Hope it's big enough to see.
  #4427
Old 10-10-2014, 04:22 PM
TimsTA's Avatar
TimsTA TimsTA is offline
Default Check this 74' out
http://www.carsinbarns.com/new259.htmlHope someone can save this one someday!
74 Super Duty Trans Am
  #4428
Old 10-10-2014, 06:07 PM
Beat me to it..
  #4429
Old 10-10-2014, 08:45 PM
Beat me to it..
Not that the factory was super precise in the placement of the shaker engine call out decals, but that SD 455 decal looks abnormally high. Wonder what the VIN says...
  #4430
Old 10-10-2014, 08:59 PM
SD73's Avatar
SD73 SD73 is offline
Actually that looks pretty accurate. Most people restore them on the low side.
  #4431
Old 10-11-2014, 10:23 AM
Norwood's Avatar
Norwood Norwood is offline
Is that picture dated?
  #4432
Old 10-11-2014, 11:27 AM
TimsTA's Avatar
Not sure if picture is dated, but the website usually has weekly updates. Would be nice to know the story behind it! Wonder if those are the original Uniroyals on it. Interior looks pretty good. Maybe it had Engine problems and was parked.
  #4433
Old 10-11-2014, 07:16 PM
Brewster's Avatar
Brewster Brewster is offline
Cool picture of a bird delete custom interior duty and odds are it sports a/c and an automatic?
  #4434
Old 10-11-2014, 07:55 PM
Norwood's Avatar
I'm just wondering if that picture is twenty years old.
  #4435
Old 10-11-2014, 10:37 PM
Probably a good thing I seem to favor '70s then... I won't have to worry about intentionally mis-positioning the shaker decals
  #4436
Old 10-12-2014, 04:22 PM
Judging by the font of the letters... I would say yes.. Probably a very low mile car.
  #4437
Old 10-12-2014, 04:39 PM
Decal placement for scoop:
  #4438
Old 10-12-2014, 06:27 PM
Brew,
It's a non A/C car with an automatic.
  #4439
Old 10-13-2014, 07:12 AM
The Boss's Avatar
The Boss The Boss is offline
What's the story on this one - anyone have any history?
http://www.ebay.com/itm/171491328203...;3AMEBIDX%3AIT
And go racin' in the street.
  #4440
Old 10-13-2014, 07:25 AM
Brewster's Avatar
Cool, most of them came with a/c making this car a little more desirable.
John, the lineman used jigs as starters regarding the placement of all decals however once experienced that diminished. Bottom line anything was possible when it came to the locations of these decals as we have seen.
