If fan has a thermal clutch on it have you tried another fan?? They do go bad..
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
Do you have non A/C pulleys or A/C ones? The pulleys on a A/C car for the water pump and balancer are sized (diameter) differently than the non A/C ones. Check to see what you have. I've seen 10-15 degree drops in temperature just by changing pulleys to get the water pump turning faster.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
