Old 12-22-2014, 07:07 PM
Brewster's Avatar
Brewster Brewster is offline
Nothing??? Come on Mikey what are you thinking???
Old 12-27-2014, 04:43 PM
transam1972 transam1972 is offline
Default HERES to the NEW YEAR
...more likely, what was I thinking...in 1985 I wanted to replace my T/A that was totaled...the 72 that I got had the cheap silver repaint and needed 1/4s so if not for that I am certain I would have thought differently...but I will say that the forum did twist my arm and convince me that Lucerne blue is the way to go (I would have had Cameo white a Lucerne underbelly)...plus I already had a white car, I should embrace the change...actually if you can envision it done..Lucy blue, deluxe black,auto with air and honeys w/o trim rings..it should make one fine TRANS AM...actually the scoop and air cleaner is in the shop and is getting painted very soon...and I cannot wait to add the decals, 455 H.O.!!!!!
Old 12-27-2014, 04:50 PM
Default SEAT BACKS FROM JUST DASHES
came in on 12/24....so a cool present for the T/A...I would recommend them...the original grain was ground off and the exterior coating glued/vac formed? on...its on for good and its totally flat...the finish around the edges is perfect..since the 1971 & 72 seat backs are not reppoped , for me this seemed the only solution and I think it works...a trim shop installed my front seat covers...71 & 72 used material to cover the rear seat bun...1973 & later use a plastic cover and a revised seat back
ID:	385603   Click image for larger version
ID:	385604   Click image for larger version
ID:	385605   Click image for larger version
ID:	385606   Click image for larger version
Old 12-27-2014, 05:00 PM
Default SEAT BACKS
cost was $150 per seat back...heck, those side covers for the seats are $55 each, of which I still need 2 more of....does anyone know what goes on the seat latch mechanism...a rubber boot?
ID:	385608   Click image for larger version
ID:	385609   Click image for larger version
ID:	385610   Click image for larger version
ID:	385611   Click image for larger version
Old 12-27-2014, 05:09 PM
Default IDLESTOP SOLONOID
can anyone explain to me the purpose of the idle stop solenoid and how should it be adjusted...it looks as though mine has moved around by the wear on 2 of the locating holes
ID:	385613   Click image for larger version
ID:	385614   Click image for larger version
ID:	385615   Click image for larger version
ID:	385616   Click image for larger version
Old 12-27-2014, 05:21 PM
Default PHOTOS
new GM replacement air cleaner duct hose came with round elbow, fortunately my car still had the drivers side set up going to the heat shield (passenger side was missing along with the stove, but not anymore courtesy of NORWOOD!)...so it has the flat spot to clear the valve cover...my 1976 T/A with the RADIAL TUNED SUSPENSION had a smaller rear sway bar, was that due to the radial tires?? any opinions??..NOV 71 build gets a repop chrome mirror...and I suppose my 1990 leafspring repop giveaway is the different style clip...lastly I saw this photo of this car...does anyone know what car it is?...I do know the 50s got a bit carried away with fins but this is THE JETSONS car??
ID:	385618   Click image for larger version
ID:	385619   Click image for larger version
ID:	385620   Click image for larger version
ID:	385621   Click image for larger version
Old 12-27-2014, 05:32 PM
Default MUFFLER
any recommendations on what to use to install the new muffler to the old pipes?...I read on line about a sealer..also look at how the original extension was never fully inserted
Name:	muffler install.jpg
ID:	385624   Click image for larger version
Name:	muffler install 2.jpg
ID:	385625   Click image for larger version
Name:	original extension.jpg
ID:	385626   Click image for larger version
Name:	original extension 2.jpg
ID:	385627   Click image for larger version
Old 12-27-2014, 10:37 PM
Bentwheelbob's Avatar
Something is definitely amiss. The mounting bracket does not look correct, but it's hard to tell from the extreme close up and angle. Here's what you're looking for.
Old 12-28-2014, 05:17 PM
Default IDLE STOP SOLONOID BRACKET
I appreciate the input...these are the parts that were on the car...can anyone say for certain that is not the correct solenoid bracket?...is it held by 2 bolts?...I will have to see if that is possible as that would throw off the angle...are these 1972 parts?...the carb is a 1975 SR and the bracket & solenoid fading seem to match...any help on this is welcome
ID:	385724   Click image for larger version
ID:	385725   Click image for larger version
ID:	385726   Click image for larger version
ID:	385727   Click image for larger version
Old 12-27-2014, 05:10 PM
1973Formula 1973Formula is offline
Your seatbacks look great. Is the vinyl they used the same as the seat material?
Thanks,
1972 Formula 400
