#621
Old 12-27-2014, 05:21 PM
transam1972 transam1972 is offline
Default PHOTOS
new GM replacement air cleaner duct hose came with round elbow, fortunately my car still had the drivers side set up going to the heat shield (passenger side was missing along with the stove, but not anymore courtesy of NORWOOD!)...so it has the flat spot to clear the valve cover...my 1976 T/A with the RADIAL TUNED SUSPENSION had a smaller rear sway bar, was that due to the radial tires?? any opinions??..NOV 71 build gets a repop chrome mirror...and I suppose my 1990 leafspring repop giveaway is the different style clip...lastly I saw this photo of this car...does anyone know what car it is?...I do know the 50s got a bit carried away with fins but this is THE JETSONS car??
ID:	385618   Click image for larger version
ID:	385619   Click image for larger version
ID:	385620   Click image for larger version
ID:	385621   Click image for larger version
  #622
Old 12-27-2014, 05:24 PM
necdb3's Avatar
necdb3 necdb3 is offline
Glenn,
I can't tell from the picture but you at least have a nut and bolt missing from the idle solenoid. I can't see the bracket to tell if it's the right one.
The idle solenoid is energized any time the key is in the run position. It's more of an anti diesel (run on) solenoid. When you the car off, it drops the idle to the base setting to make sure it doesn't run on.
Dave
  #623
Old 12-27-2014, 05:28 PM
necdb3's Avatar
Glenn,
I believe the entire 72 model year cars got a black rear view mirror.
  #624
Old 12-27-2014, 05:32 PM
Default MUFFLER
any recommendations on what to use to install the new muffler to the old pipes?...I read on line about a sealer..also look at how the original extension was never fully inserted
Name:	muffler install.jpg
ID:	385624   Click image for larger version
Name:	muffler install 2.jpg
ID:	385625   Click image for larger version
Name:	original extension.jpg
ID:	385626   Click image for larger version
Name:	original extension 2.jpg
ID:	385627   Click image for larger version
  #625
Old 12-27-2014, 05:41 PM
Default IDLE STOP
only one hole for mounting..will post some pics...gotta go everyone,,library is closing!!
  #626
Old 12-27-2014, 10:37 PM
Bentwheelbob's Avatar
Originally Posted by transam1972 View Post
can anyone explain to me the purpose of the idle stop solenoid and how should it be adjusted...it looks as though mine has moved around by the wear on 2 of the locating holes
Something is definitely amiss. The mounting bracket does not look correct, but it's hard to tell from the extreme close up and angle. Here's what you're looking for.
  #627
Old 12-28-2014, 05:17 PM
Default IDLE STOP SOLONOID BRACKET
I appreciate the input...these are the parts that were on the car...can anyone say for certain that is not the correct solenoid bracket?...is it held by 2 bolts?...I will have to see if that is possible as that would throw off the angle...are these 1972 parts?...the carb is a 1975 SR and the bracket & solenoid fading seem to match...any help on this is welcome
ID:	385724   Click image for larger version
ID:	385725   Click image for larger version
ID:	385726   Click image for larger version
ID:	385727   Click image for larger version
  #628
Old 12-28-2014, 05:28 PM
Default SEAT BACKS
1973FORMULA...I do not believe that was the intent, but yes the grain does match the seat covers...although not 100% authentic...the JUST DASHES recover solved my problem and the finish work is well done
  #629
Old 12-28-2014, 05:31 PM
Default OWNERS BOOKS
these books were in the glovebox in 1985 when I got the car..alas, no build sheet....my original rearview mirror was chrome backed...NOV.71 build..the seatbelt & mirror change was later
ID:	385733   Click image for larger version
ID:	385734   Click image for larger version
ID:	385735   Click image for larger version
ID:	385736   Click image for larger version
  #630
Old 12-28-2014, 06:23 PM
necdb3's Avatar
Glenn,
That is the wrong bracket. It looks like the solenoid is correct. You should be able to buy a reproduction bracket or find an original. The originals are pretty common on most Pontiac v8 from about 68-72.
The one Bob posted is correct.
  #631
Old 12-28-2014, 06:43 PM
Glenn - I have a spare repop bracket and the bolts that hold the solenoid to the bracket. PM me your address and I'll send it to you. Merry Christmas from WV.
  #632
Old 12-29-2014, 11:34 AM
Default PARTS
...THANKYOU BOB!!..if I recall, you offered me that once before but I turned you down..I suppose I thought it would magically turn into the correct part?!..who knows what that bracket is..and I thought I had everything covered...thankyou for the generous offer and I will be taking you up on that!...thanks again BENTWHEELBOB...pm sent
  #633
Old 12-29-2014, 02:37 PM
Default NECDB3
DAVE, and thankyou for checking out and helping me with this solenoid dealio...correct always wins!!!
  #634
Old 01-09-2015, 05:27 PM
Default IN SEARCH OF THE ORIGINAL OWNER THREAD
thanks to those that were helping me on that thread..but a special thanks to RICKSGTO who even with my incorrect spelling found both of my original owners...I just checked NJSTEVES 1973 Formula thread and he is now 2 for 2 in this search!..when I first posted that thread I knew someone had done it, just not you..I believe I now know how you came up with the info... that was a more intelligent starting point...and my misspelling did not help...anyway I never/ever would have thought that the woman that I bought the car off of in 1985 would still live in the house..in fact they are both alive so I may still be able to find out about the history..most important the SR engine and maybe photos...the library closes at 5 so I gotta go...I was going to post more regarding this but next time..I should have done this sooner but I am always late to the party
  #635
Old 01-09-2015, 05:39 PM
And she said?
Congrats on finding her.
  #636
Old 01-17-2015, 10:32 PM
Formulabruce's Avatar
Originally Posted by necdb3 View Post
Glenn,
pre late DEc'71 built cars I have parted all had stainless mirrors, and my old formula 455 which a member owns here had a stainless one when new
Here is a pic, just after the Valence was changed it seems, only about a month old. Dont drool on the wheels and caps guys... those came with this car . They were gone ( thankfully) when I owned it briefly LOL Yes the grill is all Argent silver , pic has bad shadows.. this car came unspoiled but it was tossed in the trunk, just like we did at my dealership to make a deal work, with an appointment at the body shop
" Long may we DRIVE !"
  #637
Old 01-17-2015, 10:42 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
just saw your post on contacting the owners, glad I was able to help with it! One day I hope to find the original or at least an early owner on mine but the trail went cold about 5 owners back. Post some details of what you find out from them when you can. Always interesting to hear about original owner contacts.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #638
Old 01-17-2015, 11:35 PM
necdb3's Avatar
That's weird, I owned a Nov 71 built 72 f455 back in the 70's and it had a black mirror. I currently own a 3/72 T/A and it's black.
I have a early built 72 GP also and to the best of my knowledge, they did the same thing. it's black.
  #639
Old 01-18-2015, 07:57 AM
Brewster's Avatar
Brewster Brewster is offline
Love the old picture Bruce, it doesnt look to bad with those caps and rings.
  #640
Old 01-18-2015, 02:16 PM
Default life in general
they say what doesn't kill you makes you stronger...we shall see..contacting the owner(s)..is on the back burner, ..lets see what 2 months time brings me...thanks for posting!!!
