Old 12-30-2014, 04:44 PM
boardog boardog is offline
Default engine frame mouts
does any one reproduce the frame side motor mounts for a 70 or a 71?
Old 12-31-2014, 05:42 PM
Will the 70 thru 74 frame side mounts work for a 70 model with a 400?
Old 12-31-2014, 06:23 PM
necdb3's Avatar
necdb3 necdb3 is offline
should be the same as a 350- 400- 455 have the same mounts.
Old 01-01-2015, 01:07 AM
FunctionalShaker FunctionalShaker is offline
Not all years have the mounting holes in the same locations. I don't remember which ones, but this has been discussed on here before.
Old 01-01-2015, 01:59 AM
cnc's Avatar
cnc cnc is offline
Yep they are different
http://www.forums.maxperformanceinc....d.php?t=648942
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best [email protected] Lookin for 11's
Old 01-01-2015, 01:16 PM
There you go. So 70/71 are the same.
Old 01-01-2015, 04:44 PM
thank you very much for the info. now to find a set. If anyone has a lead on a set please let me know. again thanks
Old 01-02-2015, 12:25 AM
Have a pair of '70-71 frame brackets in a '70 V8 Bird. No engine or front clip on car, shouldn't be extremely tough to unbolt, trying to remember if bolt heads are above the frame brackets, or if the nuts are up top, like on same vintage Pontiac A-body's. Have a homemade "fishing" wrench to get to the bolt heads in Abodys w/o torching the springs, will dig it out and see what can do this weekend.
Old 01-02-2015, 04:25 AM
The bolt heads are on the top & the nuts are on the bottom , I think they do that just to make them hard to get off. Also they are the same as the A-body frame mounts. Still damn hard to get off. Drill, chisel or fire is the best ways to get those off.
Old 01-02-2015, 08:45 AM
johnta1 johnta1 is online now
Maybe on the 455 GTO?
Old 01-02-2015, 11:09 AM
TooManyT/As TooManyT/As is offline
If you're not in a big hurry, I should have a set of the frame mounts available within the next month.
1971 Firebird
1979 10th Anniversary Trans Am (For Sale)
2009 G8 GT
Old 01-02-2015, 12:10 PM
edvisme edvisme is offline
Somewhere amongst my stash of 70 firebird parts I have a pair of these.
Old 01-03-2015, 03:33 AM
The frame mounts from a 73 A-body with a 400 will work on the birds as well, the mounts from a 73 A-body with a 455 wwill work also as long as you use the corasponding motor mounts. Both will work as long as long as you use the motor mounts for the same size engine. Right now I use the 400 mounts with my 455 in my 73 GTO. The difference in them is in the size of the motor mount which is longer in the 455 then the 400. But you can use either one & they will work.
Old 01-23-2015, 10:09 PM
roadrunner roadrunner is offline
If you still need a set I have a set off a 70 Firebird laying in the shop.
