Old 01-12-2015, 11:58 AM
1969Judge's Avatar
1969Judge 1969Judge is offline
Send a message via AIM to 1969Judge
Default WTB Misc 1969 Parts
I am looking for a few misc. 1969 Lemans/GTO parts:
Original square head intake manifold plug (need 2)
Oil dip stick and tube
Temp sender wire (12-18 in) with original boot in good condition from an original engine wiring harness (would consider taking the entire harness if preferred) (need 2)
If anyone can help with any of these items please let me know.
Thanks,
Scott
Old 01-12-2015, 02:37 PM
rare4k's Avatar
rare4k rare4k is offline
oil dip stick with A/c or without I have with A/c
Old 01-13-2015, 07:07 AM
Scott Thelander's Avatar
Default parts
dip stick
ac non ac
my water tempsenders dont have boots....
picture is from 3 different harneess all 69 with their ends in my hand
Scott
ID:	387333   Click image for larger version
ID:	387334   Click image for larger version
Old 01-13-2015, 08:20 AM
1969Judge's Avatar
I need the non-A/C dip stick. Sorry, didn't think about that when I posted
I appreciate the information about the wiring harness. I saw an original Fremont car and it had a boot on the temp sender wire so I thought that was how they came. If you have 3 harnesses without a boot then they either didn't all come with one or it was removeable.
Old 01-13-2015, 08:41 AM
Default Hi
one of those 3 IS my original fremont may 28th judge harness..
I have seen the boots on the idle stop/drop solenoids..
I am sure you will get more info as time passes here
the dip stick is 25 shipped non ac ... I have 2 long handle sticks
I would send the cleaner/better of the 2
Scott
Old 01-13-2015, 10:16 AM
1969Judge's Avatar
Scott,
After I read your comments I dug out the photos I took of the car I had seen. You are absolutely correct, the temp sender did *not* have a boot. I was mistaken. It was the idle solenoid boot I had mixed up in my head. So now I only need the original connector and 12-18 inches of the green wire so I can splice it into my harness. Thanks for setting me straight on that.
I will take the dip stick and appreciate you offering me the better of the two. We can exchange the details via PM.
Thanks!
Scott
Old 01-13-2015, 06:35 PM
notime's Avatar
notime notime is offline
Scott, there is a boot in the temp wire plug. Look close, little black rubber filler in black plastic plug. I will buy them from you. Let me know. Thanks
WWW.SUPERCARCREATIONS.COM
Old 01-13-2015, 11:45 PM
Default hmmmmm
Ille get em back down and peek at em
I thought it was a little black goo from the factory splashed on for keeping it clean
I thought it looked flexible........
Ille check em out tomorrow
thanks
Scott
Old 01-16-2015, 10:50 AM
1969Judge's Avatar
Scott,
I just sent you a PM. I ended up going out of town for work a couple of days and wasn't near a computer.
I am definitely interested in the wires also.
Thanks,
Scott
Old 01-16-2015, 07:08 PM
Default thanks
I will get the dip stick and tubes and the wire packaged up later tonite
Scott
Old 01-19-2015, 08:05 PM
Default I have got one
but I would like to keep it as a spare..
If you locate just one and not a pair we could chat ...
Scott
