When forcing nitro in, you definitely consider strength over weight. Your pistons are almost 200 grams heavier than mine, but mine wouldn't last for a burnout in your application.
http://www.youtube.com/watch?v=t9eWgLd0q-U |
Yea, you do need the extra weight in some power adder applications. When we were first working the tune-up a couple years ago we bent one of those 1.094 VascoJet wrist pins. I couldn't believe it!. It was bent .003" The flat top pistons are almost .400 thick. As far as pistons for NA and high RPM Pontiacs, Because of the short cylinders, I would try to keep as much structure and support in the skirt area as possible. Certainly around the pin boss and the underside of the piston, they can be light.
eagle 6.8 rods, probe 4.155 pistons, 2160 Bob weight
